Removing antenna
Old Jun 29, 2005 | 02:14 PM
jfrayzier's Avatar
jfrayzier
Default Removing antenna
This is probably a stupid question, but how do I remove the antenna? I figured I just unscrew it, but it won't budge. Maybe I just need to try harder, but if that's not the way to do it I don't want to break anything.
There is nothing in the manual that I can find about it.
Old Jun 29, 2005 | 02:16 PM
Herknav's Avatar
Herknav
Default RE: Removing antenna
unscrew it. if it doesn't budge, repeat to yourself, "righty-tighty, lefty-loosey" and try again. Make sure you use the correct size wrench, or you might leave unsightly marks...
Old Jun 29, 2005 | 02:36 PM
MobyDickDog's Avatar
MobyDickDog
If the lefty-lucy thing doesn't work, try a pair of bolt cutters. Only then will the left-lucy thing finally work.
Old Jun 29, 2005 | 02:47 PM
Herknav's Avatar
Herknav
This is how much time I have this morning...
You will note the wrench is a 3/8...
Old Jun 29, 2005 | 03:04 PM
voodoo612's Avatar
voodoo612
Herk, you the MAN!
Another piece of advise, if you are worried about nicking the paint,
try putting a t-shirt around it and use an adjustable wrench.
I take mine on and off all the time because of the cover.
Old Jun 29, 2005 | 06:42 PM
lostsoul's Avatar
lostsoul
complicated technical procedures should be posted in the right forums.
Old Jun 29, 2005 | 06:47 PM
2Stangs's Avatar
2Stangs
I ♥ Acer
ORIGINAL: Herknav
Sure you don't want to make a video?
Old Jun 29, 2005 | 06:55 PM
ChewbaccaD's Avatar
ChewbaccaD
ORIGINAL: 2Stangs
We could use it as an intermission when we make combine all of the burnout vids
Old Jun 29, 2005 | 07:10 PM
mauiboy's Avatar
mauiboy
Do it again!!! [sm=jawdrop.gif] [sm=jawdrop.gif] [sm=jawdrop.gif] [sm=dontgetit.gif]
[IMG]local://upfiles/16389/D51DF3A31C394D33B1D50EE31C36CE0B.jpg[/IMG]
Old Jun 29, 2005 | 07:14 PM
Mister Roper's Avatar
Mister Roper
ORIGINAL: mauiboy
With the bolt-cutters!
