Sequential problem
Old Jun 30, 2009 | 11:25 AM
Lakers1's Avatar
Lakers1
Default Sequential problem
This past weekend I swapped out my tail lights for a set of smoked tail lights. It should of been a easy process but now the 3rd outer most bulb on my driver side turn signal doesn't come on. The other two lights on the driver side still sequence with the turn signal. I also had the same problem with the 3rd outside light on the passanger side but I just put a new bulb in and it works now. The light still comes on with the headlights just not with the turn signal. I noticed when I was placing the tail lights back in the blue wire from the 3rd bulb got caught with the metal screw and the wire got cut. I clamped the wires but could this be the problem?
Old Jun 30, 2009 | 12:33 PM
avengence's Avatar
avengence
I would solder the line and heat shrink it just so its a good connection. But also the 2nd filament in the bulb could be damaged. Try using the other bulb in there just to rule it out.
Old Jun 30, 2009 | 12:45 PM
Lakers1's Avatar
Lakers1
I tried a couple of new bulbs but none worked. I'll do the soldering and heat shrink and see if that works.
Old Jun 30, 2009 | 03:41 PM
Nuke's Avatar
Nuke
Also possible is a dirty contact. Unplug the harness and spray some contact cleaner on both the male and female plugs, then replug and unplug them a few times to "wipe" the contacts.
Old Jun 30, 2009 | 04:59 PM
157dB's Avatar
157dB
Cut & Paste Expert
The crimp or short took out the semiconductor in the sequencer for that filiment.
Its new sequentials for you.
Old Jun 30, 2009 | 05:12 PM
Lakers1's Avatar
Lakers1
I was hoping it wasn't something like that. What set would you reccemmend? I have the Webelectric currently but if I have to but a whole new set I was looking at the CDC sequentials
Old Jun 30, 2009 | 05:54 PM
Ecorse's Avatar
Ecorse
I would email the folks at WebElectric describing your problem before I replaced the sequentials. They seemed very helpful whenever I've contacted them.
Old Jun 30, 2009 | 06:05 PM
Javdog's Avatar
Javdog
Hey Ryan give this a try its worth a shot they might replace them and save you some coin.
Old Jun 30, 2009 | 06:10 PM
Lakers1's Avatar
Lakers1
I sent them a email on sunday just waiting to hear back. I don't really want to buy a whole new set. I got other mods planned lol
Old Jun 30, 2009 | 10:07 PM
rls82959's Avatar
rls82959
One of my lights didn't work on my CDC's. I tugged on the wires a little bit and a wire popped out of the heat shrink. Bad solder joint.
Probably not, but worth a check....
