rattle help
Old Jul 19, 2009 | 01:34 AM
abe86's Avatar
abe86
Default rattle help
hey guys, quick questions about rattles
i want to remove the passenger side window control switch housing, but i'm not sure if it just pops out or what... i wanted to put some butyl tape under it to try and get rid of the rattle...anyone know how to remove it?
also, my driver side side mirror sometimes rattles from the music, is there any way to tighten the mirror to the body? someone posted there was a screw u could tighten, but i don't see one..
Old Jul 19, 2009 | 09:09 AM
avengence's Avatar
avengence
I cant help you with the control switch housing but I can help you with the rattling mirror. I had the same problem and I fixed mine.
https://mustangforums.com/forum/2005...-included.html
It was very easy and took about 30 minutes for me to do. Give it a try.
Old Jul 19, 2009 | 10:40 PM
abe86's Avatar
abe86
thanks about the window, i'll see if i get around to it or maybe i'll have the dealer do it...as for the window switch housing anybody know if it pops out? although i just printed a tsb for that so if i do take it to the dealer i'll make them fix that as well.
Old Aug 21, 2009 | 01:02 PM
d_ames117's Avatar
d_ames117
I guess this is a month late, but the part that the switch sits on top of pops out of the door by pulling it toward the inside of the car. Then you can pull the top switch panel out easily.
Dustin
Old Aug 21, 2009 | 01:55 PM
harraid5711's Avatar
harraid5711
not to pile on.....but does anyone have a good fix for the rattle where the A pillar meets the dash on the driver side? I tried one fix i found on here, where you insert a thick piece of fabric under the plastic from the dash.....didn't work. it's driving me mad.
Old Aug 22, 2009 | 10:12 AM
mmdpg's Avatar
mmdpg
Sorry the pictures from the TSB wouldn't copy over but here is the text. You could search the web for the TSB and see if you can find it in PDF format with the pictures. Hope this helps.
A-PILLAR RATTLE NOISE TSB 08-24-10
FORD:
2005-2009 Mustang
ISSUE
Some 2005-2009 Mustang vehicles may exhibit a
rattle noise where the A-pillar meets the dash area.
This rattle may be due to worn, missing or off
location tape under the dash panel and/or A-pillar
dual lock (velcro) fastener(s) not seated.
ACTION
Follow the Service Procedure steps to correct the
condition.
SERVICE PROCEDURE
NOTE
DASH INSULATOR WAS EXTENDED UNDER
THIS AREA FOR 2008 AND 2009 VEHICLES.
(FIGURE 1) FOR 2005-2007 VEHICLES MULTIPLE
VARIETIES OF TAPE WERE USED UNDER THIS
AREA. (FIGURE 2)
1. Remove A-pillar trim.
2. Inspect for tape under flanged edge of dash
panel. If tape is missing or damaged, then add
or replace with improved tape. This tape has a
plastic top coating to protect the felt tape from
wear. Install felt tape with adhesive side down.
(Figures 1-2)
Figure 2 - Article 08-24-10
3. Attach tape to end of screwdriver. (Figure 3)
Insert under dash panel flange with plastic side
of tape up. (Figure 4) Press down on dash
panel to secure adhesive. Hold pressure on
dash while removing screwdriver.
Figure 1 - Article 08-24-10
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a
Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation
determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin
(TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is
available through Ford Motor Company’s on-line technical resources.
Copyright ã 2008 Ford Motor Company Online Publication Date November 25, 2008 PAGE 1
TSB 08-24-10 (Continued)
Figure 3 - Article 08-24-10 Figure 6 - Article 08-24-10
5. Install A-pillar. Press to securely mate dual lock
fastener. (Figure 7)
Figure 4 - Article 08-24-10
4. Inspect both A-pillar trim and A-pillar sheet
metal to make sure both dual lock (velcro) Figure 7 - Article 08-24-10
fasteners are present. Replace if missing.
(Figures 5-6) PART NUMBER PART NAME
7R3Z-6321702-A Felt Tape
5R3Z-6303552-AA Dual Lock - Sheet Metal
W790192-S900 Dual Lock - A-Pillar Fasteners
WARRANTY STATUS: Eligible Under Provisions Of
New Vehicle Limited
Warranty Coverage
IMPORTANT: Warranty
coverage limits/policies are
not altered by a TSB.
Warranty coverage limits
are determined by the
identified causal part.
OPERATION DESCRIPTION TIME
082410A 2005-2009 Mustang: 0.3 Hr.
Figure 5 - Article 08-24-10
Secure A-Pillar Trim
Following Service
Procedure ONE SIDE (Do
Not Use With 04104A)
PAGE 2
082410B 2005-2009 Mustang: 0.4 Hr.
Following Service
Procedure BOTH SIDES
(Do Not Use With 04104A)
DEALER CODING
CONDITION
BASIC PART NO. CODE
6303598 25
PAGE 3
Old Aug 22, 2009 | 10:18 AM
mmdpg's Avatar
mmdpg
http://www.stangmafia.com/.../3076d1...b-08-24-10.pdf
Here is the full TSB
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
UrS4
Sep 30, 2015 10:13 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
movielover40
Sep 15, 2015 10:37 AM
tmdm
Sep 4, 2015 06:45 PM
