Idle issue
Old Jul 23, 2009 | 08:34 AM
VistaGT's Avatar
VistaGT
Originally Posted by Nuke
Clutch in and come to a stop. Shift into 1st gear while waiting for the light. No need to shift into neutral. I've driven manual for over 30 years and only shifted into neutral to coast if my left foot itched or my sock needed to be pulled up.
You've been keeping your foot on the clutch for 30yrs???
The proper way IS to leave the car in nuetral. By leaving the clutch to the floor all you're doing is wearing the clutches life away. There's no reason not to let the car sit in light at neutral.
......you must go through a lot of clutches LOL
Old Jul 23, 2009 | 08:55 AM
Nuke's Avatar
Nuke
Actually, I've only replaced 1 clutch on an SUV after 120,000 miles of towing. That vehicle had 205,000 miles on it when I sold it to a friend. I think he said he replaced the clutch at about 300,000 miles. My other vehicle with manual was sold after 180,000 miles and I never had to replace the clutch in that car.
I DO tend to downshift half the time, otherwise I coast until engine RPM's are about 1800, THEN I'm on the clutch which is usually pretty close to being at a stop. Since I've driven my manuals very little in city traffic, it hasn't been a problem. I figure I'm on the clutch nearly half as much as if I clutched to put her in neutral and again to put her in gear.
To the OP, let us know what's causing the high idle when you find the smoking gun. Seems this is an issue for a few.
Old Jul 23, 2009 | 09:33 AM
VistaGT's Avatar
VistaGT
Some clutches are built tough! The highway milage I guess is the reason you got such great life out of them.
I guess, everyone can drive how they would like I'm just simply stating that keeping the clutch in during stop lights will wear the clutch out faster than if you didnt keep it in. You're correct this is exacerbated by a lot of city driving! It also depends on the car.
Old Jul 23, 2009 | 09:35 AM
VistaGT's Avatar
VistaGT
Just so you know......Not trying to knock you Nuke, just stating a fact. No hard feelings
Old Jul 23, 2009 | 02:00 PM
thewarmachine's Avatar
thewarmachine
Sounds like a loose vacuum hose.
Old Jul 23, 2009 | 02:18 PM
kevinmalec's Avatar
kevinmalec
I have an 05, V6 (Manual) too and am experiencing the same issue over 6 months now. Once I installed the CAI it lessened a little, however it still idles high when I come to a stop. I normally hit the gas pedal and the idle goes back down to normal. If anyone knows what the cause is, let us know. =-)
Old Jul 24, 2009 | 12:45 PM
GA05GT's Avatar
GA05GT
Try to clear the computer by disconnecting the battery like the others have stated or clear w/ tuner....
Then in your manual check under the battery section where it states "RELEARN IDLE"
1- make sure your car is cold
2-start the car (do not touch anything) leave it sit till at operating temp.
3- after 1 min of the car at running temp turn on your A/C
4- let A/C run for 1 min
5-then drive normal for 10 min at low speeds w/o A/C on
This worked for me, good luck!!
Plus check the TB and clean out good!! it might look fine, but these TB's are VERY touchy as stated in other posts.
Good luck, Hope this can help!
Old Jul 24, 2009 | 02:45 PM
Nuke's Avatar
Nuke
Absolutely none taken. Were simply here for fact-finding and opinions.
Old Jul 26, 2009 | 11:33 AM
mtbiker's Avatar
mtbiker
im going to check into this. is there anything to spray on them to check for a leak?
Old Jul 30, 2009 | 03:16 PM
kevinmalec's Avatar
kevinmalec
Any resolution????
