Bounce and Bump Steer
Old Jul 28, 2009 | 06:37 PM
ptaylor_9849's Avatar
ptaylor_9849
Default Bounce and Bump Steer
The rear end of my 07 GT steps out a little when I hit bumps. My buddy's 09 has the exact same tires (Nitto 555) and his rides better. Were there any changes made to the rear shocks over the years on S197's? If not, can you recommend a shock that would soften the ride a bit?
Old Jul 28, 2009 | 07:06 PM
foolio2k4's Avatar
foolio2k4
thats cuz of the live rear axle. Aftermarket dampers help lessen it but doesnt cure it.
Old Jul 28, 2009 | 10:07 PM
rshamekh's Avatar
rshamekh
This would probably get more response in the handling section.
Maybe you should ask one of the moderators to move it there.
Old Jul 28, 2009 | 10:26 PM
Sp3kter's Avatar
Sp3kter
your suspension is worn his is still pretty new that is why.
Old Jul 29, 2009 | 12:11 AM
candymanjl's Avatar
candymanjl
I've noticed it with my car and it's only got 1900 miles. it's the solid rear that's causing the issues. hopefully when I get the rear UCA and LCA's with the panhard bar everything will settle down.
having the solid rear is annoying for handling, the mustang is the first car I've owned with a solid rear. but at least when I add a lot more power I don't have to worry about the rear end blowing up
Old Jul 29, 2009 | 07:03 AM
ptaylor_9849
Thanks guys.
Old Jul 29, 2009 | 09:44 AM
Norm Peterson's Avatar
Norm Peterson
Mostly shocks, though the PHB could be responsible for a tiny bit of this. Bump steer is a front suspension geometry issue involving the tierod and suspension component inclinations, NOT what you're experiencing with the rear "stepping out".
They're a little ways up the food chain, but single-adjustable Koni Sports (aka "Yellows") set at about 1/4 turn up from full soft seem to have quieted the back end down a bit. That's with OE springs, and I'm still on the OE struts.
Norm
Old Jul 29, 2009 | 02:13 PM
ptaylor_9849
Excellent Norm. Exactly what I was looking for.
Thank You
Old Jul 31, 2009 | 10:17 AM
Jason0279's Avatar
Jason0279
I had this same issue but when I replaced the stock LCA's with BMR LCA's it improved. It's still there a little but the rear wheels seem to get planted back to the pavement a split second sooner after a bump.
- Jason
CS2007
Jun 25, 2019 09:45 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
