Can the camera be added?
Old Jul 30, 2009 | 11:15 AM
maddog69's Avatar
maddog69
Default Can the camera be added?
I have a 2010 Grabber blue GT with Nav and I didn't order the Rear Camera thinking I was going to change out the wing, now I think I may have made a mistake :-( Does anyone know if the parts can be ordered and simply plugged in?
Thanks,
Jake
Old Jul 30, 2009 | 01:09 PM
10GTSTANG's Avatar
10GTSTANG
Hey Maddog cant help you with your camera question, but thanks for putting the pictures of you car up. I have the same car minus the nav. I am contemplating putting black on mine, I did not know how it would look with those wheels. I think on the hood I'm going to follow those outer contour lines up to the bend at the front of the hood.
Old Jul 30, 2009 | 03:02 PM
wilkinda's Avatar
wilkinda
2010 Section Moderator
I contemplated buying a car the dealer had on the lot already that did not have the camera. To add it was gonna cost me almost $1100 for the parts and installation.
I love the look of the camera spoiler as it is much wider than the standard, however, if your considering either a Roush or GT500 rear spoiler...neither are compatible with the camera option...
Old Jul 30, 2009 | 05:04 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Originally Posted by wilkinda
...however, if your considering either a Roush or GT500 rear spoiler...neither are compatible with the camera option...
Unless.......................................... you're a mad modder!
Old Jul 30, 2009 | 05:40 PM
wilkinda's Avatar
wilkinda
Tru dat Pascal...and you are the "Mad Modder"
Old Jul 31, 2009 | 07:25 AM
dconfer's Avatar
dconfer
I have the camera with the nav and just love it. Noticed this morning when backing into my space at work that you can see the rain drops on the lens. Looks weird.
Old Jul 31, 2009 | 01:39 PM
Badbee's Avatar
Badbee
Default Wireless rear cameras
Go to u tube and type in wireless rear car cameras and you will see several that include installation instructions. I don't know how good the video quality will be but it sure make the install easy.
Old Jul 31, 2009 | 02:50 PM
Xcelsius's Avatar
Xcelsius
if you have SYNC, you run into the issue of replacing the rear view mirror and not having the needed microphone hardware when you use an add on kit. Unless you could find a way to run the aftermarket camera feed into an OEM camera/SYNC microphone mirror, I think you would be stuck.
But i just remembered you have nav...hmmm, Is there a feed in the rear of the Nav that is a common connection (non-proprietary)? If its common, you could feed an aftermarket unit into the head unit, not sure about reverse activation and switching to that view..maybe the dealer has capability to enable that.
Old Jul 31, 2009 | 05:05 PM
wilkinda's Avatar
wilkinda
Went to the dealer this morning for getting my steering wheel plastic replaced where it was scratched and and asked the parts guy about the rear camera. If you wanted it like factory OEM..you would need the camera, wiring harness and camera rear-spoiler. parts alone are almost $780 plus installation....
Old Jul 31, 2009 | 06:45 PM
dconfer's Avatar
dconfer
Holy smokes mine was only 240.00 from the factory. Thats what the window sticker says.
