Replacing Pads and Rotors
Old Aug 21, 2009 | 10:38 AM
NS4U's Avatar
NS4U
I take it's pretty obvious one the rear pistons have fully retracted?
Front pistons need a c-clamp to compress them, correct?
Old Aug 21, 2009 | 11:25 AM
NS4U's Avatar
NS4U
Regarding the spring clips. I couldn't find anywhere that sold them separtely. I tried my local NAPA and autozone. I plan on wire brushing the clips to clean them then greasing them. Any objections?
Old Aug 21, 2009 | 06:33 PM
NS4U's Avatar
NS4U
one more thing, i just took the caliper off, and the rotor looked to be held on by some sort of thing washer that held it tight to the hub, do I need this? one did not come up with the new rotors i bought
Old Aug 21, 2009 | 07:31 PM
Jersey Stang's Avatar
Jersey Stang
Originally Posted by Goldenpony
Clockwise, just like turning a screw in.
That's what I meant.
Old Aug 21, 2009 | 07:37 PM
miloman's Avatar
miloman
Originally Posted by Stango36
You will need a caliper tool with backplate to compress it its not as easy as screwing it in. Most tool shops will carry it, I suggest going to a wholesale tool shop that where i got mine for a very good price.
http://www.amazon.com/dp/B0002SQUJU/...SIN=B0002SQUJU
Something like this
that is pretty pricey. I bought this kit from amazon: http://www.amazon.com/Astro-Pneumati...0901364&sr=1-1
Old Aug 22, 2009 | 12:02 AM
spuddogg's Avatar
spuddogg
That's exactly what I did but now I get a squeak from the rear under moderate braking.
Pulled 'em back apart and greased them up - was nice and quiet for about 15 minutes and then squeaky again.
Ah well, they're Hawk HPS pads which I've heard tend to be squeaky anyways.
NAPA online sells the spring clip kits for about $12.
The little washer thingie on one of the wheel studs is used at the factory to keep the rotor on during assembly. No problem taking it off and discarding.
Some would even say it's advisable to do so (I did).
Old Aug 22, 2009 | 02:30 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
That washer should be removed and was used at the factory to hold the rotor on while the car was being made.....some people have had issues with them being left on with aftermarket rims.
Old Aug 22, 2009 | 11:31 AM
157dB's Avatar
157dB
Cut & Paste Expert
Those keep the rotors on the hubs before the
calipers are installed on the assembly line.
No need to replace and if you have aftermarket
rims with no void in the mounting surface for
the clips, then they HAVE to be removed for the
rim to seat flat against the hub/rotor assembly.
Stealership. The pads should have had them included.
Grease is not the thing to be using haphazzardly on
brake components to reduce squeeking. There are
specific products that can be used to quiet brake squeeling.
Grease just attracts brake dust and over time the calipers
wont be sliding on the pins properly and you will have all
sorts of 'new' undesired noises that occure at other times
besides braking....
Correct , just a C-Clamp to compress the front pistons.
I always just compress them before removing the calipers
with a big screwdriver, but thats just me and my old ways...
Cant believe no one has sent you over to The Ford Gararge
Old Aug 25, 2009 | 07:12 AM
NS4U's Avatar
NS4U
well I've got the 4 wheels done and they seem to be in good shape. However, when i go to put on the parking brake, I noticed that car "gives" a little when i give it gas. The parking brake is definetly doing something, but it's not holding the car tight.
I guess I need to adjust the parking brake cable? Where can that be found on the mustang? is it difficult to do?
5.0muscle
Jan 11, 2016 01:17 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
9550
Oct 26, 2015 05:01 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
