Unlock both doors with one button press?
Old Sep 9, 2009 | 11:18 AM
Boondoggie's Avatar
Boondoggie
Default Unlock both doors with one button press?
Can the mustang do this? I know you can get an explorer or a focus to do it, but I haven't found the "cheat code" to make the stang do it...
Old Sep 9, 2009 | 11:20 AM
Shadowc's Avatar
Shadowc
the system needs to be set in a * double pulse mode, wich unlocks both doors.. Not sure how to do it on a factory system thou never tried it.
Old Sep 9, 2009 | 11:26 AM
Chris07GT's Avatar
Chris07GT
yeah, because pushing the button twice is a real pain in the a$$
Old Sep 9, 2009 | 11:54 AM
Shadowc's Avatar
Shadowc
I just called my VIPER tech support to see if they have or had a way to do this, and ( NO ) so i then called a buddy ( tech ) here at ford and sad to say there PCM's are only programmed to do single stage unlocks..
Only way to have both doors is to add aftermarket keyless system or alarm combo.
thats what i have come up with.
Old Sep 9, 2009 | 12:02 PM
Nuke's Avatar
Nuke
LOL! That's what I was thinking, too. Sometimes after that second button push, I need a nap.
Old Sep 9, 2009 | 12:17 PM
Starfire's Avatar
Starfire
It use to bother me because the car I had before the stang was a single press and I would forget, but now I'm use to it.
Old Sep 9, 2009 | 12:22 PM
Boondoggie's Avatar
Boondoggie
It was a question about a feature normally found on ford vehicles, not a slight against your honor...
Should I make a "yeah, cuz shifting gears yourself is a pain in the ***" peeing contest retort?
Old Sep 9, 2009 | 12:30 PM
SirKnightTG's Avatar
SirKnightTG
I find this feature annoying as well. I'd switch to a single press to open both doors (like my previous stang) if I could. Having to double tap is just dumb.
Old Sep 9, 2009 | 01:05 PM
Chris07GT's Avatar
Chris07GT
If it makes you feel better, than yeah, go for it
Old Sep 9, 2009 | 01:06 PM
Shadowc's Avatar
Shadowc
I am going to play with mine on some dead time and try some things, see if i cant find a way to make this work =)
