Ready for Snow
Old Sep 20, 2009 | 01:06 PM
KingB21's Avatar
KingB21
Default Ready for Snow
Well, winter tires or supersnake paint job, guess the paint will have to wait. I did not add the sencors for the winter set. Is there a way to disable the tire sencor pressure alarm once I put the tires on ??
Old Sep 20, 2009 | 01:48 PM
conor1148's Avatar
conor1148
with my car, there is not alarm, just the light in the dash cluster.
so i suppose if you can tolerate the annoying orange light, you're good. unless there is supposed to be an alarm that my car doesnt do?
Old Sep 20, 2009 | 03:24 PM
05 Mustang's Avatar
05 Mustang
as far as I know, there is no way to disable the light on the dash, other than unplugging it. if you choose to not put sensors in the new wheels, you'll just have to hit the reset button everytime you start the car and learn to live with that light on the dash....
unless something changes, that's what I'm going to be doing when I upgrade to my new wheels & tires. as much as I'd like to do it the right way, that additional $150-$200 is hard to swallow after buying new wheels, tires, center caps, etc...
thanks for the pic, as funny as it sounds, I've never seen a set of "winter" tires
Old Sep 20, 2009 | 04:28 PM
HypromanGT's Avatar
HypromanGT
What brand/model tire did you go with? I'm going to have to be doing the same sadly...
Old Sep 20, 2009 | 05:11 PM
KingB21's Avatar
KingB21
they are 235/50R18 Nokia Studded tires, and not cheap.
Old Sep 20, 2009 | 05:32 PM
avengence's Avatar
avengence
Can you reuse the TPMS sensors from the stock wheels in aftermarket wheels?
Old Sep 20, 2009 | 07:57 PM
Starfire's Avatar
Starfire
http://www.tirerack.com/tires/tires....omCompare1=yes
Fit and work perfectly, I use them on mine.
Old Sep 20, 2009 | 08:08 PM
cad316's Avatar
cad316
Yeah, I've never seen snow tires either! Looks like a truck tire.
Old Sep 20, 2009 | 08:14 PM
Nuke's Avatar
Nuke
Smart choice (over the paint job). Be sure to add a sand bag or 2 in the trunk.
There's no way to DISABLE the TPMS. Assuming your winter tires are NOT mounted on your stock wheels, you can either buy new sensors and band kits and install them in your new wheels or reuse your old sensors with new band kits in your new wheels.
Old Sep 20, 2009 | 08:26 PM
Tylus's Avatar
Tylus
haven't seen snow tires for some time.
btw, love the signature pic
