08 Sirius Portable install
Old Dec 5, 2009 | 02:04 PM
msaleen05's Avatar
msaleen05
Default 08 Sirius Portable install
I have an 08 GT with the Shaker500 and factory Sirius radio. I also have a portable Sirius Stilletto radio that I use in another vehicle and in my shop. I prefer to use the Stilletto and would like to install it with an in-car kit and mount but would prefer to use the factory antenna. Does anyone know how the factory antenna is integrated into the harness and if I can adapt it for use with the Stilletto receiver?
Old Dec 5, 2009 | 03:11 PM
5T4NG's Avatar
5T4NG
your gunna have to pull out the factory deck, look at the adaptor thats on the end. You might have to re-terminate it if thats possible.
Old Dec 5, 2009 | 03:34 PM
157dB's Avatar
157dB
Cut & Paste Expert
The OEM Sirius received is in the trunk and
thats where the antenns lead you want is.
Its mounted on the right side of the trunk (behind the
shaker1000 speaker/amplifiers if so equipped).
The antenna lead on the back of the dash mounted
radio is for the AM/FM receiver thats in it.
The SAT receiver is located in the trunk and
is only CONTROLLED by the in dash unit.
The OEM antenna lead will have to be extended
up to the dash console area. A good quality
coax with low loss at SAT frequencies will
be mandatory in use as well as the proper
antenna connectors installed on it
Thats a big task even with a good knowledge of
SAT antenna connectors used in the industry.
Not easy for the casual Stilletto listener.
Old Dec 5, 2009 | 04:11 PM
Nuke's Avatar
Nuke
There must be a way to convert the exisiting sat antenna to extend into the passenger compartment. I'd certainly consider that. Otherwise, your install is a breeze.
157db, since I bought a Shaker 500 out of an '08 to replace the Shaker 500 in the g/f's '06 (no Sirius) will I be able to set her up with Sirius or do I need a seperate receiver? I thought the Shaker 500's were Sirius ready and nothing more than a sat antenna was required.
Old Dec 5, 2009 | 04:23 PM
gandyj's Avatar
gandyj
You will need a sirius satelite receiver to do what you want, I did it when I bought my car.
Old Dec 5, 2009 | 04:34 PM
msaleen05's Avatar
msaleen05
Nuke- agreed the only thing that has concerned me is the antenna. I like the Stilletto better because I can record directly from the sat when I like a song and can use it as my MP3 player when I can't find something on that I like.
157db- thanks for the good information. I'll have to try and locate the Sirius receiver in the trunk and see what the antenna cable looks like. I used this one in the shop for my outside mounted antenna. It's way to long for a car but if the connectors are the same maybe it will still work.
http://www.antonline.com/p_Terk--SIR...s)-_225636.htm
Old Dec 5, 2009 | 05:52 PM
gandyj's Avatar
gandyj
In all likely hood the antennae should not be an issue. Of the several sirius antennae that I've seen the only difference might be that the connector will have a plastic shroud around it, some of the older ones had it. Now look here http://cgi.ebay.com/ebaymotors/Ford-...item3356c2fd5f at the sirius receiver used by ford. The shroud is actually on the receiver compare your stilletto antennae to the plug on it.
I went back and reread your original post, if you are talking about the antennae that actually plugs into the back of the Shaker 500 it's a regular antennae plug. I've had mine out more than once.
Last edited by gandyj; Dec 5, 2009 at 06:03 PM. Reason: Reread posters original thread
Old Dec 5, 2009 | 07:08 PM
JimC's Avatar
Super Moderator
"Sirius ready" simply meanst that it will accept the receiver unit. You will need to get the receiver from Ford if you want to control it through the Shaker 500. The radio in the dash merely controls the Ford Sirius receiver in the trunk.
For aftermarket you can get a Sirius receiver, antenna, and the Sirius FM adapter to plug into the back of your Shaker 500 for static free reception. But you can't control the Sirius receiver with that set up, only the volume.
Old Dec 6, 2009 | 04:15 PM
breathegood's Avatar
breathegood
You can purchase an antenna extension from Sirius. They make a 20' and 50'. I have a lifetime subscription on a Sportser 5 that gets shared between two vehicles. This is what I did. I purchased the 20' extension, disconnected the antenna from the factory reciever, plugged in the extension, and ran it up to the dash. This is probably the solution that offers the least amount of headache, and leaves all of the factory stuff intact.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
