Rough Running While Cold
Old Dec 8, 2009 | 05:56 PM
davisr014's Avatar
davisr014
Default Rough Running While Cold
When my car is cold it will run rough. The wide band indicates it is going from way rich to way lean. the meter maxes out at 10 and 16. Is this normal? The problems clears up once it is warm. Thanks for the help.
Old Dec 8, 2009 | 06:31 PM
hammeron's Avatar
hammeron
upon cold start up, the vehicle is in
open loop mode. that means it does not
use the o2 sensors to attain a specific
a/f. i believe the pcm uses values from
tables in the tune, until the o2's are
warm enough to provide a stable voltage.
Old Dec 8, 2009 | 06:35 PM
davisr014's Avatar
davisr014
It did not do it before the supercharger install. Is this something i need to worry about?
Old Dec 8, 2009 | 07:26 PM
hammeron's Avatar
hammeron
i don't know if you should worry about
because i don't how rough it is. i have
heard that it's pretty common though, if you
try to drive off after only a minute or two.
Old Dec 8, 2009 | 07:34 PM
hardcore302's Avatar
hardcore302
for like 3 bucks you can try a water remover for your fuel lines. might work, who knows?
Old Dec 8, 2009 | 10:47 PM
ChiDiddy's Avatar
ChiDiddy
i have the same issue ever since my whipple install. Mine is a custom dyno tune. Happens when my car starts in the morning, and i drive off, the car would sputter for like 3-5 secs, then drive normal. The rest of the day, its perfectly fine.
Old Dec 8, 2009 | 10:59 PM
rmssch89's Avatar
rmssch89
Since I got my bamachips race tune, during cold weather only (40ish and below) my car will run a little rough at startup. It will start, run rough for a second or two, then run around 1500rpm for a few seconds, then return to normal and will be good to drive. Since it only happens in the cold I just figured it was a temperature related issue and nothing to worry about. I'm sure you have nothing to worry about as well.
Old Dec 9, 2009 | 12:59 AM
05fastblk's Avatar
05fastblk
same here, Its like it starts and is really loud (neighbors hate it), sputters a little, settles sometimes until I take off and it wll go away for the rest of the day.. Im running a tune also not sure if its related to that...
Old Dec 9, 2009 | 10:28 AM
rmssch89's Avatar
rmssch89
My best guess is that the tunes we have cause the engine to go really rich at startup (can sometimes smell some fuel,) which on a cold engine may lead to the sputtering. It then speeds up to keep itself running until everything evens out.
Old Dec 9, 2009 | 03:07 PM
jstang07's Avatar
jstang07
I haven't installed gauges yet so I am not sure what my a/f is but after I installed my e-force the car idles way high at cold start up (like 2500), which it did not previously do, then slowly creeps down to normal after a minute or so. I called brenspeed and they did not think it was anything to worry about, just said it is in open loop mode and trying to heat up the sensors as described above. Mine does not idle rough though, just higher rpm.
