Heater
Old Dec 10, 2009 | 09:04 AM
WeinerDog's Avatar
WeinerDog
Default Heater
Anybody else notice how outstanding the heater is on the 2010? (And perhaps earlier models since they also have the 4.6).
My car sleeps in a heated garage at night but other cars I've had took several minutes to start blowing hot air. This car starts blowing heat two blocks from my house, literally about a minute.
Yesterday, ambient temp was 36 degrees when I went out at lunch and the car had been sitting in a covered, unheated garage for 5 hours (i.e. it was cold!). I had nice heat in less than two minutes.
Bravo, Ford!
Old Dec 10, 2009 | 11:55 AM
7up's Avatar
7up
+1 ^^ Mr. W-Dog.
Also, I've noticed the front windshield defroster works amazingly well & fast.
Old Dec 10, 2009 | 07:02 PM
WeinerDog's Avatar
WeinerDog
Wow, pony. 89 views and only your response. I guess we've got the only quick heaters.
Old Dec 10, 2009 | 08:02 PM
chronos's Avatar
chronos
Actually, not to go off on a tangent, but I have noticed V8 and V6 take a little longer to heat up than 4cyl. When I had my Accord it would heat up while idling in the garage. I always give my cars a minute to warm up (the engine) before I pull out and the heat would be really hot on the Accord. This 4.0 and my V8 truck take a little longer. Why? I don't know. Maybe more mass to dissipate heat, the way the block circulates the water, I dunno. Of coarse that doesn't mean that I prefer the 4 banger, just making an observation and keeping your thread alive.
Old Dec 10, 2009 | 08:48 PM
7up's Avatar
7up
Originally Posted by chronos
Actually, not to go off on a tangent, but I have noticed V8 and V6 take a little longer to heat up than 4cyl. ... Maybe more mass to dissipate heat, ...
That'd be my take.
The bigger the engine, the more metal (aluminum/steel/alloys) there is absorb the heat; consequently, there is less initial heat transfer to the passenger cabin.
Automotive engineers (and other related type engineers) would be able to give you a more definitive answer on this though.
Old Dec 10, 2009 | 08:49 PM
joekr's Avatar
joekr
It was blistering cold the last 2 mornings here in KC and +1 on the heater. It kicks in fast as hell.
KC is great but 8 degrees? TOO COLD!!!
Old Dec 10, 2009 | 09:03 PM
jtstakelin's Avatar
jtstakelin
My V6 heats up quick too. It was very nice to have this morning/afternoon too!!!
Old Dec 11, 2009 | 01:45 AM
FastDEW's Avatar
FastDEW
It is the combination of engine size and the material. Your Honda was likely all aluminum engine (heads and block) which will transfer heat more quickly than an iron block engine. Your V6 Stang and the likely the truck are iron block.
You will find that the 4.6 will heat a little faster than the 4.0 - this is because both engines are very close in size but the 4.6 is all aluminum and will transfer heat more quickly.
If you want a SLOW heater, try any diesel engine. Diesels do not make heat well and they will have a PTC (electric strip) heater in the heating duct to help boost the heat when it is first started or very cold. In fact a diesel will idle its way to totally cold if left a while. Even the T-Stat wont keep an idled diesel hot. This is why you see semi trucks with radiator covers and why they have idle control systems to raise the engine RPM during extended idle periods.
Okay, I know - Too much info - But I am done now
Old Dec 11, 2009 | 06:29 AM
jdmcbride's Avatar
jdmcbride
We have heaters?!?!? Never used it. I even have seat heaters that I don't use.
Old Dec 11, 2009 | 07:49 AM
WeinerDog's Avatar
WeinerDog
Now, that's just mean...
