Removing the headrests 2007
Okay so I have pushed the button and given it a tug but can not see to get the headrest to come out??
I am looking to take the headrest cover off so that I can get some custom embroidery done but for the life of me am completely stumped by what should be a simple process!
If it is really simple.... then yes I am a muppet!!
Thanks in advance
ELMO
Thanks in advance
ELMO
Yep, look at the little square plastic parts the the head rest poles go into and you will see a very little hole. Put a paper clip or anything you can find that will fit into that hole and push in on it at the same time your pulling up on the head rest and it will come out.
This is driving me nutz! Every thread I read where I think to myself "I'll just go into the garage and check that out on one of the Stangs...", only to remind myself that they're both in storage. I need some valium...
EDIT: Under the assumption that 157db's link doesn't open for you.
Thanks buddy, as always very helpful. 1st link worked fine, and useful, however the second one opened but could not navigate.... probably a MAC thing!
Thanks
