Help with LCA relocation bracket
Old Dec 29, 2009 | 08:14 PM
robs's Avatar
robs
Default Help with LCA relocation bracket
Making home brew relocation brackets for the J&M LCA's... wheel hop is still a real issue...
Side brackets (1/4" stock) are easy. I relocated 2-1/8" from factory... I have not welded these in.. I think they're too low for factory ride height... Was thinking about making another set at 1-7/8" apart...
Anyone got measurements on how far below factory bolt hole (with factory ride height) the LCA should be relocated???
Brackets (will be fully boxed in the rear after burning in):
Here's the LCA before and after with the 2-1/8" spacing... looks like its' too much??
Old Dec 29, 2009 | 08:57 PM
SirKnightTG's Avatar
SirKnightTG
Your last pic looks like my UMI LCAs at the lowest relocation bracket hole (most extreme setting). The more of a downward angle (like in the last pic) the better (at least for eliminating wheel hop and improving traction).
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Explosive
Oct 2, 2015 07:45 AM
UrS4
Sep 30, 2015 10:13 AM
