new hood so now i need?
Old Jan 4, 2010 | 08:16 AM
NJ3's Avatar
NJ3
Cervinis claim their hoods don't require hood pins, I call BS. My Cervinis hood flaps around at 50 mph. I called Cervinis tech line and adjusted my hood stops per their instructions and using variations of their methods. My Cervinis hood still flapped while driving so I installed a pair of Shelby hood pins in the outer bump stop locations, no more flapping.
As far as hood struts you should use Cervinis of similar, I think Steeda struts are the same. If you use Redline make sure you use rivets made for use with fiberglass. https://www.cervinis.com/large.aspx?img=1351_1_big.png 05-09 Cervini's Hood Strut Kit
Part # 7103
Old Jan 4, 2010 | 08:21 AM
NJ3's Avatar
NJ3
I'm still using the Cervinis windshield washers that came with my hood, but when I do change them I'll do it like this.
See here https://mustangforums.com/forum/4609693-post4.html
deekum1627's Avatar
deekum1627
yea i just looked at the cervinis hood struts they looks nice
Old Jan 4, 2010 | 08:23 AM
deekum1627's Avatar
deekum1627
Part # 7103
they just bolt right where the hood bolts right. also the bolts for the hood seem smaller then the factory did you notice this. and what cervinis kit are you usin for the wipers
Old Jan 4, 2010 | 08:42 AM
NJ3's Avatar
NJ3
Yea my hood bolts seemed to be smaller as well. The struts bolt in using the hood mounting bolts, I believe you get longer bolts. See below pdf.
https://www.cervinis.com/files/instructions/7103.pdf
The washers I'm using are the ones in "figure A" in the below pdf. They just mount to the underside of the hood.
https://www.cervinis.com/files/instructions/1176.pdf
Old Jan 4, 2010 | 08:53 AM
deekum1627's Avatar
deekum1627
what shebly pins did you use thanks for all the help man
Old Jan 4, 2010 | 09:07 AM
jdmcbride's Avatar
jdmcbride
Anyone know where you can get the Shelby GT500KR hood pins for a GT hood? They look the best to me.
Old Jan 4, 2010 | 09:10 AM
deekum1627's Avatar
deekum1627
yea those are the nicest and the only ones i would ever use
Old Jan 4, 2010 | 10:29 AM
loots06's Avatar
loots06
My new hood comes in tommorrow....my wife wants me to get hood pins..
Old Jan 4, 2010 | 10:49 AM
jdmcbride's Avatar
jdmcbride
I would get them if they were available and fit the stock GT hood.
Anyone have any thoughts?
