shaker 500 help!
Old Jan 17, 2010 | 02:58 PM
H911STANG's Avatar
H911STANG
Default shaker 500 help!
i've got a 2010 mustang with the shaker 500 audio system in it. i just picked up a 15" kicker comp sub and a 2000 watt pyramid arctic amp. How in god's name do i remove the shaker face plate to run wiring from the front to the back?
Old Jan 17, 2010 | 03:11 PM
Adam's Avatar
Adam
Here you go. Once you have the center console area removed, simply unscrew the two bolts that hold the faceplate at the bottom. At that point you can ease it out and unplug the single wiring harness it's connected to. Then you'll be presented with this
Old Jan 17, 2010 | 03:46 PM
WeinerDog's Avatar
WeinerDog
There are no subwoofer outputs on the Shaker so you're going to have to use speaker level inputs. Why not just use a trunk-loc to tap the rears?
Old Jan 17, 2010 | 05:45 PM
bluestang35's Avatar
bluestang35
AJ, do you have any more pics on the front bezel removal? I'm planning on wiring a sync
lock pick to the nav unit for full control and cant find any diagrams for removal.
Is it the same as the 05-09 units where you removal the console first?
thanks for any help.
H911 stang - just install a pac SNI -45 line out converter with amp trigger wire to rear speaker wires. Works well with my alpine amp and sub.
Old Jan 17, 2010 | 05:51 PM
Iskwezm's Avatar
Iskwezm
The SNI-45T is the replacement fot the Trunk-Loc, same part, different name.
Old Jan 17, 2010 | 06:13 PM
Adam's Avatar
Adam
No. Just follow the roush guide it'll take you through most of it.
Old Jan 18, 2010 | 12:20 AM
BL00DSH0T's Avatar
BL00DSH0T
Have you actually removed the Shaker500/SYNC radio out? I have tried but couldn't get the radio to pull out more than an inch and that was not close enough to get to the wiring harness to unplug it.
I just tapped into the rear speakers and didn't need a turn on lead with the MTX amp.
Old Jan 18, 2010 | 12:28 AM
Adam's Avatar
Adam
No. There must be an easy way to get it out, I wonder what the trick is.
Old Jan 29, 2010 | 08:53 PM
Tomstang2005's Avatar
Tomstang2005
Ive got a bizaare issue with my Shaker 500 in my '05 'stang. At first it would only play when Im out of gear ( Park- Neut ) but that subsided and it started working fine. but now it only plays while the ignition is off ,( acc mode ) once started the music dies. all power to the system is there just not the music. anyone got a clue on the bizaare issue ?
Old Jan 30, 2010 | 06:47 AM
wilkinda's Avatar
wilkinda
2010 Section Moderator
Where in FL are you located? I just started seeing a new KonaBlue stang in the area where I live. Riverview / Brandon area near Tampa
