Need Help Boys
Old Jan 28, 2010 | 01:45 PM
HEPJKC's Avatar
HEPJKC
Default Need Help Boys
Just got back from the dealer and ordered the new 2011 GT. I stuck with the standard 3.31 axle. A 3.55 and 3.73 were available. Not an expert but what are the pros and cons?
Old Jan 28, 2010 | 02:16 PM
Tony71502's Avatar
Tony71502
https://mustangforums.com/forum/5-0-...bers-read.html
This shouldn't even be in the 5.0 section IMO. Completely diff engine.
Higher ratio = more acceleration + lower top speed.
Old Jan 28, 2010 | 02:35 PM
AdderMk2's Avatar
AdderMk2
Banned
lol.. +1.. post in the right friggin section
Old Jan 28, 2010 | 04:55 PM
NoGo95GT's Avatar
NoGo95GT
Why would the OP want anything more than 3.31's. Everyone knows that 2.73 gears are the best gears for acceleration There are no cons with 2.73's.
Old Jan 28, 2010 | 07:26 PM
americaniron's Avatar
americaniron
The 3:55, and 3:73 gears will give you better acceleration. The 3:31s are better for gas milage, but only slightly. If I were you I'd have gone with one of the other choices.
Old Jan 28, 2010 | 07:32 PM
Margarita Girl's Avatar
Margarita Girl
Is the tide gonna reach my chair?
The 3.73 gear gives you more torque. It takes torque to get the car moving. Better torque means faster acceleration.
I have 4.10's
Old Jan 28, 2010 | 08:44 PM
05 Mustang's Avatar
05 Mustang
+1^^
I would have definitely gone with either the 3.55's or the 3.73's in lieu of the 3.31's.
Old Jan 28, 2010 | 09:03 PM
dstang10's Avatar
dstang10
I have 3.31's in my 10' and I hate them so much. You should go back and get the 3.73's if you don't you'll be wishing you would of and eventually switch them out for a lower gear. I can't wait till I get some 3.73's
Old Jan 28, 2010 | 09:17 PM
JDWalton's Avatar
JDWalton
go with the 3.73s imo.... the car will feel like it has 100 more HP compared to the 3.31s. With the con being lower top speed, your only talking theoretical top speeds anyway. The car doesn't have enough power to hit its mechanical top speed, so you have to go with its wind resistance limited top speed.
Say the 3.31s theoretical is 220 and the 3.73s theoretical is 200, the 3.31 can only push against the wind with enough force to hit 150, where as the mechanical advantage gained with the 3.71s you might actually be able to hit a little faster, say 160. So you actually gain acceleration and top speed the way our cars are set up. Unless you have enough power to hit the mechanical top speed. Which you wont.
Old Jan 29, 2010 | 05:38 AM
HEPJKC's Avatar
HEPJKC
Default Thanks
Thanks everyone who helped me make a great decision. I quickly called the dealer and replaced the 3.31 with the 3.73 for the 2011.
Thanks!!!!
FivePointToTheOh
Mar 9, 2020 10:26 PM
treesloth
Sep 28, 2015 07:03 AM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
Sep 16, 2015 03:07 PM
Kenta08
Sep 2, 2015 10:33 AM
