Steeda driveshaft install
Old Feb 15, 2010 | 08:10 PM
Riptide's Avatar
Riptide
Default Steeda driveshaft install
Steeda includes no instructions with this thing. Has anyone ever installed one of these?
They want you to use red loctite on the pinion nut and also the bolts mating the driveshaft to the front and rear flanges.
Isn't that going to make for a serious PITA if I ever need to remove this to install a STS or for any other reason?
Old Feb 15, 2010 | 09:35 PM
thewarmachine's Avatar
thewarmachine
Steeda has a lot of instructions on their site. Have you checked for it there?
Old Feb 15, 2010 | 09:38 PM
Riptide's Avatar
Riptide
They don't seem to have anything up for the driveshaft.
Old Feb 15, 2010 | 09:57 PM
Nuke's Avatar
Nuke
You want Red Loctite to keep that bad boy from unleashing on you at the worst time. When it comes time to take it apart, some serious power is required but they'll come undone.
Old Feb 15, 2010 | 10:25 PM
brunobluto's Avatar
brunobluto
Its not a big deal, Ive taken my ds off a few times after putting loctite on the bolts each time. Just requires a little extra effort.
Old Feb 16, 2010 | 08:08 AM
Riptide's Avatar
Riptide
Yeah but the blue or the red stuff? I've been told the red is pretty much permanent.
Old Feb 16, 2010 | 08:14 AM
timmbo's Avatar
timmbo
Sometimes heat is necessary to break the red loose. I have always used blue without a problem on driveshaft bolts. If they aren't coming loose on the big C4500 ambulance chassis I work on they won't come loose on your Stang as long as you torque them properly.
Old Feb 16, 2010 | 10:23 AM
jz's Avatar
jz
I'm really surprised they didn't include instructions. I've ordered serveral things for my car from Steeda and they have provided the best instructions. I wonder if they forgot to add them to your package? You should try calling them.
Old Feb 16, 2010 | 10:58 AM
Grabber's Avatar
Grabber
Hey Rip, sup bud?
Anyhow, use he red loctite. I would only use that on the first 3 threads of the tip of each bolt. That prevents the bolts to stay in, and not voluntarily back out from the constant vibrations. It will be hard to remove, but, just use a breaker bar, and they will come loose.
I do have a write-up for a Shaftmasters Driveshaft, which is the same. I did this on my back, with basic sockets, torque wrenches, etc.
It's pretty easy. I HIGHLY suggest having a friend there to help, as on your back, the stock driveshaft is heavy, and you need the extra hand to remove it safely, and install the new one safely.
I will find that How-to ( which is very detailed i might add) and PM you the info. Congrats on the new DS!!!
-Chris
Old Feb 16, 2010 | 03:57 PM
Riptide's Avatar
Riptide
Thanks for the help.
Steeda did get me some instructions. They aren't up on the website.
They do recommend red loctite. I will just be careful with it and do as you suggest. As long as I follow the "little goes a long way" philosophy I shouldn't have a permanent install on my hands.
Now I just need to find a decent air wrench for $60-100, the socket I need, and a creeper. Hoping to get away with spending less than $200 on the tools but it beats paying a shop to do this when it really isn't that big of a deal to do the flange.
If I follow the instructions and torque that pinion nut back down properly with my tq wrench then if things are off balance it's not my fault.
