Tire size question
Old Feb 19, 2010 | 01:22 PM
kjbnastynati51's Avatar
kjbnastynati51
Default Tire size question
quick question, does a 255/50/17 tire fit the stock 17" inch rim. If not what is the best option for increasing width
Old Feb 19, 2010 | 02:32 PM
Orion_240's Avatar
Orion_240
it can fit but is not recommended. 245 would be safer, if you had to go wider with the stock rim.
Your best option is obvious= new rims.
Old Feb 19, 2010 | 02:38 PM
Allstar's Avatar
Allstar
if you really like your rims tho.. and want a cheaper route u can have them widened for around 100 bux a wheel
Old Feb 19, 2010 | 03:32 PM
PHX8839's Avatar
PHX8839
Depends on the brand, check the web site of the tire manufacturer. For example, according to nittotires.com, their Nitto 555's in 255-50-17 will fit a 7-9 inch rim. They are pretty much exactly the same diameter as stock tires.
I've heard of people putting much wider tires on their stock rims. I would say as long as you go by the manufacturer's instructions you should be fine. I plan on putting these tires on my car in the next month.
I myself would be interested in getting 2 more stockers like mine and and getting them widened for drag radials, unless i could find ones that look just like stock.
Do they cut the wheel in half and add a metal ring to the middle to widen them?
NorthAmericanTuning
Nov 9, 2016 11:44 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Gary Ugarek
Sep 16, 2015 08:04 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
