Tire Size Question
Old Jul 27, 2005 | 01:28 AM
SpikeGT's Avatar
SpikeGT
Default Tire Size Question
Will a 255 fit alright on 9.5" rim? i have heard it will fit, but that 9.5 is the max width. Someone else said they don't think it will fit. Does anyone here know for sure? Thanks
Old Jul 27, 2005 | 02:43 AM
VistaBlue 06 GT's Avatar
VistaBlue 06 GT
Default RE: Tire Size Question
ORIGINAL: SpikeGT
It depends. 255/??/?? What size exactly? If it is a low profile tirelike a 255/40 it will fit. If it is a 255/55/18 or something like that, then no. This is just based on the bfg g-force tires. I don't know if other brands will run exactly the same, but they should be really close.
Old Jul 27, 2005 | 10:46 AM
huffhuff's Avatar
huffhuff
most any major brand tires website has a spec chart. look up the particular size and the rim requirements should be there. the inportant thing is for the sidewalls to be as close to vertical as possible. you can stretch a skinny tire over a wide rim for the low rider look but that akes the sidewalls very vulnerable to punctures and the tire can pull off the bead in a very tight turn at speed.
Old Jul 27, 2005 | 12:00 PM
SpikeGT's Avatar
SpikeGT
the tire size is 255/45-18 on a 18 X 9.5" rim
Old Jul 27, 2005 | 12:02 PM
CainMotorsports2102's Avatar
CainMotorsports2102
ya it will fit. we do nothin but fit wheel and tire combos all day long. the 255 will fit.
Old Jul 27, 2005 | 12:08 PM
SpikeGT's Avatar
SpikeGT
thanks everyone for the info. i checked the tire manufacturer site and it is approved for a 9.5 " rim.
Old Jul 27, 2005 | 11:41 PM
LimeStang05's Avatar
LimeStang05
255 is milimeters. Thats about 10 inches. It will fit no matter the aspect ratio (30, 40, 45..etc...)
Old Jul 28, 2005 | 08:10 AM
VistaBlue 06 GT
ORIGINAL: LimeStang05
Check into that. BFG lists on thier website that a 9" rims is max for a 255/55. Also I did nothing but sell tires for my last 2 years in college. Sidewall construction is an important factor in what fits and what doesn't. Oh well, doesn't matter. 255/45 will fit so you are in good shape.
NorthAmericanTuning
Nov 9, 2016 11:44 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Gary Ugarek
Sep 16, 2015 08:04 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
