Rear gas cap emblem
Old Mar 1, 2010 | 02:48 PM
RichieCal's Avatar
RichieCal
Default Rear gas cap emblem
I am gonna take off my rear gas cap emblem, and install a new one...any tips on how to remove the old one SAFELY?..I believe that the 3m tape is all that is holding it on
Old Mar 1, 2010 | 03:17 PM
nottey4.6's Avatar
nottey4.6
Masking tape around the sides. I heated mine up with a blow dryer to about 80F. Dont know if that helped at all. I used a plastic wedge and carefully pryed it off. It comes off pretty easily but the 3m tape is a PITA. I picked off the biggest chucks I could with my fingers and used a rag and alcohol to get off the rest. Hope this helps.
I should be more specific just in case. But I put masking tape just under the lip of the cap and about 3 inches away on both sides just to ensure the wedge didnt scratch the paint.
Old Mar 1, 2010 | 06:04 PM
Langor's Avatar
Langor
I had a black out panel covering mine. I took it off, and where the missing emblem was a huge chip. Looks like the previous owner took it off with a flat head screwdriver. I wouldnt recommend it. I now have a v6 pony one on it, and it covers it up. So if you don't care about the paint behind it you could do that.
Old Mar 1, 2010 | 08:57 PM
charliebrown266's Avatar
charliebrown266
Fishing line to cut through the badge and tape and the go gone.
Old Mar 1, 2010 | 09:04 PM
RichieCal's Avatar
RichieCal
Thanx for the tips..I will try heating it also..I was gonna use a plastic wedge of some sort.I do have a blackout panel to put around it, but still will be careful incase I wanna take it off someday...Flat head screwdriver!! LOL
Old Mar 1, 2010 | 10:00 PM
2010V6Stang's Avatar
2010V6Stang
BEWARE! Possible Scammer
Oh man this was the biggest pain for such a simple thing. I tried to get mine off on a 35 degree day which was really the problem. I used the heat gun and levers and all sorts of things but it took a while and destroyed my trunk (not too bad but to me). Anyway that doesnt really matter better it has a decklid now and you will never see it again. I would wait for hot weather if you can.
Old Mar 2, 2010 | 09:52 AM
SpookyStang's Avatar
SpookyStang
I took fishing line, wrapped it around a pen on one end and another pen on the other end. I heated up the badge with my blow dryer, and 'sawed' through the adhesive, using the pens as leverage and so the fishing line wouldn't cut into my fingers. When I felt resistance from the adhesive, I stopped and heated it up again. I continued this process until I was finished.
Getting the adhesive off is the worst part. I basically dabbed the entire area with Goo Gone and let it sit. Then, I heated it up and used a foam pad and my fingernail to remove the leftover adhesive. It took a while and I thought I was never going to get it all off, but I eventually did.
Old Mar 2, 2010 | 10:24 AM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Let it sit in the sun and use fishing wire.
Old Mar 2, 2010 | 12:12 PM
Cal26Stang's Avatar
Cal26Stang
Fishing line, Goo gone, patience and a 6 pack, heat gun..
Old Mar 2, 2010 | 05:39 PM
RichieCal's Avatar
RichieCal
Fishing line!?...I live in NYC! LOL..Now I gotta see where 2 get fishing line near me..Oh Well ;-)
