3.73 gear pkg
Old Mar 5, 2010 | 09:53 AM
eddiev22's Avatar
eddiev22
Default 3.73 gear pkg
On my order/window sticker.. I have this gear ratio.. Is there a way to physically check though?
Old Mar 5, 2010 | 09:57 AM
discodave's Avatar
discodave
My stock gear were 3.31 and there was a sticker on the rear differential (on the outside of it) that said "3.31". Maybe look for the sticker that says 3.73?
Old Mar 5, 2010 | 10:15 AM
eddiev22's Avatar
eddiev22
I mean a sticker is a sticker, but unless you take apart the rear-end is the only way youll really know?
Old Mar 5, 2010 | 10:20 AM
discodave's Avatar
discodave
I'm sure if your window sticker (which is tied to your VIN number) says that you have the 3.73, then you have the 3.73. I'm not mechanically savvy enough to open mine up and be able to tell just by looking at the gears. But, I'm sure there are plenty of guys out there who can do it. If it were me, though, I'd trust your window sticker.
Old Mar 5, 2010 | 11:12 AM
remicks's Avatar
remicks
You should be able to check your door tag use a decoder and see what ratio you have. If you want to go further in depth you can crawl under and look at your differential and it should have a metal tag bolted to the housing showing the ratio.
Old Mar 5, 2010 | 11:40 AM
dmhines's Avatar
dmhines
You doubt the WIndow Sticker?
Jack up car ... mark the DS and tire. Turn the DS 3.73 times ... the rear wheel should turn 360 degress. If it turns more than 360 it's not a 3.73 ...
There are also many online calculaters where you can plug in tire size + rear end ratio + tranny gear ratio ... and it will tell you what RPM you should be at.
Old Mar 5, 2010 | 12:28 PM
robinsonda1's Avatar
robinsonda1
If you have a manual with dual piston calipers up front and the strut tower brace you have the 3.73 pkg
Old Mar 5, 2010 | 12:33 PM
dmhines's Avatar
dmhines
Don't freak him out ...
strut tower brace only came with 19" wheels ... not 3.73 rear package.
Pretty sure the calipers don't look any different from the outside ....
Old Mar 5, 2010 | 12:50 PM
robinsonda1
I just know I have the strut tower brace but I have the 19s and the 3.73 and on ford's website it doesn't specify which pkg had the brace so I could be wrong but either way if you pull the front wheel off you can tell if it's a dual piston caliper.
Old Mar 5, 2010 | 12:59 PM
dmhines's Avatar
dmhines
I have 19" wheels with 3.55 rear ... and strut tower brace.
