HELP QUICK!! Hurst uninstall
Old Mar 6, 2010 | 09:55 AM
harraid5711's Avatar
harraid5711
Default HELP QUICK!! Hurst uninstall
I am trying to pull my hurst to install another STS. I have all bolts out, but can't get the son of a ***** out through the console. I remember struggling to get it through when I installed it, but eventually got it.
I have a guy coming to buy the hurst in a bit and need to get it out asap. anyone have any tips?? I've tried everything and it just won't fit through the console hole. I've removed the top interior console already.
Any helpe would be appreciated.
Old Mar 6, 2010 | 09:59 AM
howarmat's Avatar
howarmat
s197 Junkie
its a sign that you should not take it out lol.....i got no clue, mine has been in forever i cant remember how i maneuvered it to put it in.
Old Mar 6, 2010 | 12:09 PM
branman1's Avatar
branman1
What are you replacing the hurst with?
Old Mar 6, 2010 | 01:38 PM
VistaGT's Avatar
VistaGT
go in from the interior. Long end first with the shift lever held back towards the shifter. go down as far as possible and then manuever the front back up. If you have a friend have them go from the bottome to help you fit it in
Sorry If it's not exactly clear, it's hard to put into words
Old Mar 6, 2010 | 03:36 PM
candymanjl's Avatar
candymanjl
just keep F'in with it. when I installed mine I had my buddy in the driver's seat lowering it in while I messed with it from under the car. it was a PITA but eventually just fell in with very little effort. who knows what happened, I'd suggest doing the same thing I did in reverse. with two people farting around with it you'll get it out.
Old Mar 6, 2010 | 03:53 PM
157dB's Avatar
157dB
Cut & Paste Expert
Same procedure in the exact same order but the reverse as when you installed it.
Old Mar 6, 2010 | 11:11 PM
harraid5711
Took about 45 minutes, but I finally got it. Couldn't tell you how, but it just eventually happened. It's like the most aggravating brain-teaser ever!
Due to the rattle and very notchy feel, I felt it was time to replace it. I got a killer deal on a new B&M short throw ($119.95) and am impressed so far. Quality seems superior to the Hurst, and she shifts are much easier!
Oh yea.....and it's QUIET
Old Mar 7, 2010 | 02:01 AM
East87's Avatar
East87
lol should have gone with MGW right from the start
Old Mar 7, 2010 | 06:35 AM
candymanjl's Avatar
candymanjl
Originally Posted by harraid5711
...I finally got it. Couldn't tell you how, but it just eventually happened.
sounds like when I was installing mine
funny that you mentioned the noise, mine did that at first and it bugged me. I saw a post where guys were adding a little oil to the bearing and that was fixing it. I kept meaning to try that but never got around to it. funny part is that mine has been dead quiet ever since then, I honestly forgot that it used to make noise
Old Mar 7, 2010 | 08:04 AM
robs's Avatar
robs
I'm sure this is late, but it's MUCH easier to install / remove from the underside of the car, driver side of the tranny.
firehorse02
Nov 16, 2015 11:28 AM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
