Foose Nitrous?
Old Mar 12, 2010 | 06:36 PM
Cobrakev's Avatar
Cobrakev
Default Foose Nitrous?
I am looking at the Foose Nitrous wheels. Is 34mm (front) and 40mm (rear) the right offset to keep the wheels inside the fender? I am looking at 20x8.5 & 20x10. What are the widest tire sizes that will fit? Does anybody have any pics that can help me out?
Thanks
Old Mar 12, 2010 | 08:19 PM
Johnboy7701's Avatar
Johnboy7701
Im running 295's out back on 20x10, and running 255's in front on 20x8.5 not sure the offset
Old Mar 12, 2010 | 09:05 PM
peter north's Avatar
peter north
i have the foose nitrous 20x8.5 with toyo proxes front 255/35/20 & 20x10 rear 295/30/20
Old Mar 12, 2010 | 10:24 PM
0NF1R's Avatar
0NF1R
JONNYBOY7701,
i could be mistaken, but in your last picture on your post, i can see the tread pattern of your front and rear wheels...
now correct me if im wrong, but it looks like your tires are flipped the wrong way.....
i mean your tires need to be dismounted, flipped 180 degrees, and then mounted again so the tread pattern can be rotating in the proper direction.....
its not good for the tire to be rotating in the opposite direction than it is supposed to be...they are not bi-directional....
here is the pic of your car...notice the tread pattern.....the thread pattern is supposed to be pointing down in the direction of the rotation....
here is the pic of your tire and the proper way is it supposed to be mounted....
sry for hijacking this thread but its important that it be corrected if its in fact mounted wrong...
Old Mar 12, 2010 | 11:52 PM
dekidex's Avatar
dekidex
what are these wheels worth used?with nitto tires?
Old Mar 13, 2010 | 12:04 AM
budders's Avatar
budders
lol, just switch the sides the two tires from one side to another, problem solved?
Old Mar 13, 2010 | 12:16 PM
Johnboy7701
Yeah I havent driven on these rims yet simple mistake... gonna go take care of it now... I appreciate the info you guys
Old Mar 13, 2010 | 02:11 PM
0NF1R's Avatar
0NF1R
hey i just figured something out lol....
im an idiot for not thinking of this before....
you dont need to dismount and remount the tires....
if the drivers side wheels are the same way, just change the drivers side wheels to the passenger side and vice versa.....
this will fix everything and put the tread pattern where it needs to be....
Old Mar 13, 2010 | 02:29 PM
Cal26Stang's Avatar
Cal26Stang
bro, get em! they are so legit
Old Mar 13, 2010 | 05:06 PM
Johnboy7701
Yeah thats all I did man, just switched them around. I have a single car garage with 2 bikes, quad and my car plus other stuff so I guess I overlooked the simple things and didnt catch it... appreciate it once again as soon as it warms up it'll be on the road...
