LED Sequential Taillights
I'm looking for LED Sequential Taillights and am curious what is a better quality option:
http://www.mossmuscle.com/Shop/ViewP...eIndexID=79161 http://www.mossmuscle.com/Shop/ViewP...mpaign=Emailer I know the WebElectric ones are good but I don't think they are offered in LEDs. |
probably the 2nd one, the first doesn't really do its job as a proper turn signal
The chase makes it look like a cop car.
The standard sequencers are DOT legal all 50 states. The chasers are debatable.... http://www.mossmuscle.com/Graphics/P...57-810_1_1.gif You've seen sequential taillights before but these take the phenomenon a step further with LED and a simpler install. No modifications to your Mustang are necessary. The LEDs last nearly forever, illuminate brighter and produce a clearer light than standard incandescent lamps. Taillights sequence once during braking and continuously during turn signal operation. http://www.mossmuscle.com/Graphics/P.../059-795_1.gif The first LED taillight kit with CHASE action. No wire cutting and no harness change out. No permanent modifications to your Mustang at all. Just pop in the LED's in place of your incandescent bulbs and go! LED's virtually last forever, are redder and produce a clearer light than incandescent bulbs. All three sections of the taillight light up during braking and turn signaling. Taillights sequence once during braking and continuously during turn signal. Included in your kit are six CHASE LED bulbs, connectors, and complete instructions. I dont get the explanation of the chasers function during braking. They chase once then what? All three bulbs then illuminate indicating braking? Thats stupid. At least they could have included a brake switch wire to avoid the chase during braking.... |
i agree, those ones don't blink right
I bought a plug and play kit for the stock taillights and bulbs that lets you select stock, sequential, or chase. the kit is awesome and installed in less than 30 minutes start to finish and truly was plug and play. it came with all new sockets for the factory lamps and the main power wire to the fuse box with the fuse, I could do it in 15 minutes if I did it again.
the little brain for it just hides in the trunk and has a jumper to select the mode you want. the brain also automatically adjusts the timing of the pattern to match the blinker rate, some kits don't and you have to manually adjust it. I picked the chase pattern since I think it looks cool and not everyone has it. if I ever get in trouble for it I can just change to the sequential mode I guess but I'm not too worried about getting pulled over for using my blinkers :) http://meter4it.com/2005_to_2009_mustang.htm here's the different patterns... http://meter4it.com/_wp_generated/wp7c4f1772.gifhttp://meter4it.com/_wp_generated/wp79b86472.gifhttp://meter4it.com/_wp_generated/wpaef9f406.gif |
Originally Posted by 157db
(Post 6875458)
Finally meter4it offers a true plug n play instead of the splice kit.
But you still seem to need to supply the unit with ground and 12VDC? Thats fine and dandy, but the OP wants LED taillights. I also see some sort of calibration adjustment indicating no self timing adjustments. WebElectrics all have self adjusting timers nowdays. :) http://meter4it.com/DSCN2196_a.JPG |
yeah I had to run a 12V wire from the fuse panel to the brain. not sure why but it took 5 minutes and all the connectors were already in place, easy.
I mentioned my kit since it works well and is super easy to install. you could get LED replacement lamps for it if you wanted and swap them at the same time if you really want LED. |
I really like the meter4it chasers, but when I bought I decided I was just to lazy to splice, and I went with the web electrics. To bad they didnt have the one 157 listed a bit earlier.
