Help! Need dummies version
Old Mar 15, 2010 | 05:26 PM
alkemist's Avatar
alkemist
Cool Help! Need dummies version
Ok, I know we have quite a few of these threads out there, but I need to know how to jack up my car DIY dummies simplified version. And yes, this is a real question
I need to put on my new wheels, I've read the manual, but I can't seem to locate the jack grooves/points. I will be using the stock jack that comes with the spare tire kit. I took a quick look (since it's wet and cold) and it was hard to see anything under the rocker molding and the tire. If anyone has pictures, it will help me tremendously, as I am more of a visual learner.
I also have to install this on the street, is it ok to install one side and then drive and turn the car around?
Old Mar 15, 2010 | 05:41 PM
howarmat's Avatar
howarmat
s197 Junkie
on each side there is a rail if you will that fits into the jack. you can kinda see it with this photo. I can draw circles if you need
Old Mar 15, 2010 | 05:55 PM
alkemist's Avatar
alkemist
Please draw circles so I can be sure
Old Mar 15, 2010 | 05:56 PM
mv22's Avatar
mv22
Great picture howarmat!
Remember, if you are installing aftermarket wheels, some require that you remove the factory washer clips on the wheel studs. My '05 had clips on two studs per wheel.
Old Mar 15, 2010 | 06:00 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Yeah Matt, I want circles too!
Old Mar 15, 2010 | 06:25 PM
howarmat's Avatar
howarmat
s197 Junkie
at the end of each rail that has the square around it there will be a place to putt he jack, it will be tough to see but you can feel for it to. kind of a notch i think.
as for the sprocket that is on the wheel stud
its a little circular metal piece. take it off before you put the new wheels on if its still there anyway
Old Mar 15, 2010 | 06:47 PM
alkemist's Avatar
alkemist
But those are rectangles!! I'm disappointed
JK!! lol
Thanks!! I'll try to tackle this tomorrow after work
Old Mar 15, 2010 | 06:50 PM
howarmat's Avatar
howarmat
s197 Junkie
phucker, that means we have to wait lol
Old Mar 15, 2010 | 06:52 PM
alkemist's Avatar
alkemist
knowing me, I'll probably end up dropping the car on my hand in the dark
They are still in the boxes, I so want a sneak peak but those are soooooo farking heavy.
Old Mar 15, 2010 | 07:06 PM
East87's Avatar
East87
So I put jack stands here after I jacked BY THE PUMPKIN...I didn't want to use/bend/mutilate the rear axle.
Idiot or no idiot? Btw...LMFAO @ catalytic converters.
/HIJACK
