Another tire question
Old Mar 20, 2010 | 07:34 AM
Topless06's Avatar
Topless06
Default Another tire question
As some of you have read i have purchased some rims with out tires. Well now its time for me to get some tires. The rims are 20x9 and the recomended tire is 275/35/20. Is there a bigger or smaller tire i can run on these and be ok? Is that sidewall to small? Thanks in advance!!
Old Mar 20, 2010 | 08:31 AM
Nuke's Avatar
Nuke
With a 20, there's not much choice in sidewall. As far as width, check the specs on the tires that you want to run. Sites like tirerack have specs for all of the tires they sell with min and max rim widths for each tire size based on the tire manufacturers specs. From a safety perspective, it's best to stay within those recommendations. You CAN go outside those specs but at your own risk.
Old Mar 20, 2010 | 10:10 AM
157dB's Avatar
157dB
Cut & Paste Expert
You really want to match the OEM tire overall diameter unless you can
change the revs per mile settings with a tuner.
There are tire calculators all over the web...
http://www.miata.net/garage/tirecalcold.html
Put in the OEM size and then spec a 20" tire.
Look for the same RevsPerMile...
http://www.1010tires.com/TireSizeCal...?action=submit
https://www.rsracing.com/tech-wheel.html
A pic of OUTSIDE THE SPECS:
Old Mar 20, 2010 | 10:20 AM
Nuke's Avatar
Nuke
Originally Posted by 157db
...A pic of OUTSIDE THE SPECS:
Yeowwww. I can almost HEAR that tire bead crying...
Old Mar 20, 2010 | 11:27 AM
loudnlow's Avatar
loudnlow
Wow... is that even safe
Old Mar 20, 2010 | 12:20 PM
siberian.mist's Avatar
siberian.mist
thats a little too big in my opinion, get 265/35/20 kdw2s all around, you wont regret it
Old Mar 20, 2010 | 12:55 PM
candymanjl's Avatar
candymanjl
nope, at that point there's so much deflection the tire is getting worked far beyond what it was designed to handle. the tire flexing while you drive is what causes it to heat up and that tire is flexing in ways it's not supposed to.
"safe" would be what the manufacturer of the tires says to do. they set those guidelines and are liable for the tire if run correctly. do something else and it's at your risk.
honestly a small stretch and I wouldn't worry, it depends what you're doing really. normal driving you can get away with a lot. high speeds on the highway or track use and you're pushing your luck.
Old Mar 20, 2010 | 02:50 PM
157dB's Avatar
157dB
Cut & Paste Expert
Sdewall flexing/deflection, either caused
by too narrow of a rim or underinflation,
is what causes high speed blowouts....
Old Mar 21, 2010 | 05:52 AM
Topless06's Avatar
Topless06
Thanks for all the info guys!!!! Now tire shopping. Where is a good to some discount tires. Dont wanna spend 200 a tire
Old Mar 22, 2010 | 08:46 AM
alkemist's Avatar
alkemist
Discounttire.com and tirerack.com; depends on what type of tire you are looking for. All season or summer. Prices will vary.
