Car randomly shutting off?
Hey everybody, I've been having trouble with my 08 GT for a few days now... I've been driving and the car will just shut itself off without me even noticing. Its happened 3 times within 150 miles, 2 different tanks of gas, everything seems to be connected properly. The engine isnt sputtering, it just shut off once when i was at a light and twice on exit ramps. The car just hit 13K miles, only mod is a c&l racer CAI with a tune... Any ideas?
Do you have a canned tune or a email like brenspd or bama?
Also, when I installed my CAI/TUNE, I did not tighten the filter and the tube to the MAF/Throttle BODY. Because of this, my MAF would sense a incorrect amount of air and turn my car off like your car does. Check and tighten the **** out of your CAI.
If that is not your problem, call your tunner and have them check out your tune.
I doubt it has to do with the CAI, since any issues there would cause you to run rich or lean, and you'd throw a code for either of those.
Sounds electrical. Check the two grounds on the upper radiator support. I had one loose one time after some installations and my car would randomly die. If it's not that, I'd check the alternator cable.
