Pics of my broken engine...
a few questions :
do you like the sandwich adaptor between the oil filter ?
how in god's name do you change the oil filter with the front sway bar in the way ?
the little rubber gasket between sandwich and block....are those things good for a few years before deterioating ?
wow...you really trashed that engine...
www.evoperform.com Evolution Performance (Fastest GT500 in the world) $4,200 for a "4.6L 3V Aluminum Short Block - Supercharged"
That would be my Playboy, I keep him around for the times I'm really sad!
Yes, the sandwich adapter is easy...
I just pull the motor to change the oil... lol For reals, I use a short filter is all.
I'd imagine they would be fine for a while since they aren't being taken on and off.
a few questions :
wow thats is all because of a freaking clogged cat which made 17lbs of boost this really sucks bruce1 sorry once again. im sure the new block will be even better once you get the build started. good luck
wat other filter ( part # ) has the same thread size but is shorter ?
