Compression : (
Old Apr 18, 2010 | 09:26 PM
Lethaldosage423's Avatar
Lethaldosage423
Default Compression : (
i got out of work early the other day and asked my boss if i could do a compression check in the bay as we were very slow.
i tested all six cylinders and every cylinder EXCEPT number six read 210 PSI
cylinder number 6 read 60 PSI the first time. i re did it and god 80 then the third time i cranked it 12 times and got 180 PSI.
So i think im burning a valve or something.
Any thoughts on this?
*We had a Ford Ranger in the shop the other day the V6 3.0L and it had barley any compression in cylinder number 4. it was burning a valve and i was told it was cheaper to replace the engine then do a valve job on these engines. The Brand new engine we got for $1200*
Old Apr 18, 2010 | 09:43 PM
siggyfreud's Avatar
siggyfreud
Your engine might have been stopped in a position with a valve on the verge of being open.
Old Apr 19, 2010 | 01:32 PM
atomicpunk's Avatar
atomicpunk
You could pull the valve cover on that side and look for anything unusual and also you could do a leak down test on that cylinder. Leak down test will give you a better idea where your loosing compression.
Old Apr 19, 2010 | 03:52 PM
Goldenpony's Avatar
Goldenpony
A way to tell if the compression leak is valve or rings is to squirt some engine oil into the suspect cylinder and recheck the compression. if it comes up, it's rings. If not, most likely a valve.
I agree with atomicpunk, a leakdown test is the best.
Old Apr 19, 2010 | 07:56 PM
Lethaldosage423
ill try pulling the valve cover see if there is anything out of the ordinary down there. if not ill give the oil thing a try.
Thanks for the help guys. It is greatly appreciated : )
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
