Learning the hard way
Old Aug 2, 2005 | 05:22 PM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
Default RE: Learning the hard way
Guys...
Don't be hard on Voodoo... I have 3 kids and could very well see all three of them making the same mistake.
My oldest son decided to replace the radio in his Ford Probe... He ended up prying out the old radio with a crow bar because he couldn't figure out how to remove it with a screw driver.. []
My daughter put Oil in the Radiator Overflow Reservoir because she noticed it was at the "ADD" mark.
My youngest son let hs car sit at a friends house for 8 days because the dash light fuze blew and he was afraid to drive it thinking it had a major electrical problem.
NOT everyone is "Mechanically Inclined"... I have a friend who is 45 years old... has 2 Masters Degrees and has to pay someone to change a door handle on his closet because he couldn't figure out how to do it himself.
I Commend Voodoo on trying to do it himself, knowing full well he was getting into something new. Everyone should be brave like he and so some stuff for themselves at least once to see if they can do it.
Also.. thanks Voodoo.. for warning others about the "sealed" transmission unit.... I knew about it reading the book.. but I know a LOT of people NEVER look at the book.. LOL.
Old Aug 2, 2005 | 05:37 PM
1fast05GT's Avatar
1fast05GT
ORIGINAL: Professor Wizard
Book? It comes with a book?
Old Aug 2, 2005 | 06:46 PM
FemmeCanuck's Avatar
FemmeCanuck
ORIGINAL: 1fast05GT
Hey, that's what I was going to say!!!!![sm=funnypostabove.gif]
Old Aug 2, 2005 | 08:02 PM
StupidTodd's Avatar
StupidTodd
wasn't trying to be hard on voodoo or to poke fun...
I put a lot of effort into asking that in the nicest way possible, I commend anyone for attempting something that they have never tried before. It's the best way to learn.
Once I ran 3000 volts from left arm through my chest out my right arm cause I was holding the wrong part of a transformer and thought I could safely touch a certain wire. The part I was holding happened to be the ground for the wire I touched. Knocked me back about 8 ft. Taught me not to do that again! And that's just one of the stupid things I've ever done. (there are lots)
Old Aug 2, 2005 | 08:17 PM
Hambone's Avatar
Hambone
ORIGINAL: StupidTodd
We have lots of time [:@]
Hammy
Old Aug 3, 2005 | 02:37 AM
algregory's Avatar
algregory
I have a GT. Manual trans. Drain for the trans is forward, bottom center. Fill hole is above it, passenger side, about half way. Nice thing is that are both operated with a 3/8" ratchet, no extensions, fitting, sockets needed. Pretty cool!
GO to your autoparts store. They have a pump to pump fluids. The one I purchased just fitts into a quart bottle and you pump away. Somewhere in $5.00 range. Bad part in my case, didn't quite fit the threads on Redline "D4" bottle. Also, recomend, you put in a 10% mix of "Tufoil" www.tufoil.com, I'm a total beleiver in both products. I firmly believe trans now shifts better.
Old Aug 3, 2005 | 12:55 PM
voodoo612's Avatar
voodoo612
ORIGINAL: algregory
Now that's the post I was looking for, thanks.
[sm=signs007.gif][sm=yeahsmile.gif][sm=signs007.gif][sm=yeahsmile.gif][sm=signs007.gif][sm=yeahsmile.gif]
Old Aug 4, 2005 | 02:28 AM
algregory's Avatar
algregory
Do yourself a favor. Check out Redline "D4" and Tufoil. Been using Redline products for years, as also the Tufoil. Don't like being without either. I'm sure the tranny shifts better.
I put off change over to Redline in engine cause Redline recomended that I wait. Did at 4.6k Did cheat a wee bit, had to add a quart at 2.5k. Used Redline At 4.6k engine oil still looked pretty much full. Now at 5.6k, still looks pretty much full.
Talked to Tufoil months ago on the newcar thing. They said not to even think of putting Tufoil in car till 5k on the clock. Recomended a 10% mix in the trans. Tufoil is pretty heavy/viscous out of the bottle. I thought "how am going to get that in the trans?" At $40/guart you don't want to waste! I pumped part of the first Redline quart into the trans, poured the Tufoil into the quart, and by the time I pumped the trans to the lip of the hole, I figured the Tufoil had found a new home!
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Oct 3, 2015 06:23 AM
guitarman376
Sep 30, 2015 05:54 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
Yantorno
Sep 30, 2015 10:29 AM
