Shifter broke
Old Apr 30, 2010 | 04:35 PM
157dB's Avatar
157dB
Cut & Paste Expert
I dont have a problem.
Tightened up my driveshaft flange bolts that Ford left loose and no jack involved.
An oil change does not warrant jacking her up either.
GT take-off muffler mod, piece of cake at ride height.
Now tire rotation is another story....
I just did a fuel filter replacement and didnt need to jack her up or nuttin.
I even have the Roush lowering springs.
5'10" 110 Lbs?
Skinny as a worm...
Old Apr 30, 2010 | 06:27 PM
X3xMONGOOSEx3X's Avatar
X3xMONGOOSEx3X
Warm
WURM
W O R M
Time to go fishing
Old Apr 30, 2010 | 06:46 PM
Riptide's Avatar
Riptide
5'10" 110 lbs?
Isn't that like anorexic or something? Dude go have a hamburger.
Old Apr 30, 2010 | 07:06 PM
JonStolo's Avatar
JonStolo
Originally Posted by Riptide
What kind of ***** featherweight doesn't need a jack to get under these cars? I'm 5'8", 170, and I'm not fat at all. There is NO way I'm getting under that car without it lifted.
Jesus I can barely fit a low profile jack under the front of this car and I'm at stock ride height.
Are you from Somalia or something 157db?
LMAO
Old Apr 30, 2010 | 08:51 PM
jayed53's Avatar
jayed53
QUESTION: What size nut do I need to buy to fit on the shifter linkage, I need to try to make it work until I get my new shifter.
NM, found tacobills writeup
Old Apr 30, 2010 | 10:52 PM
HypromanGT's Avatar
HypromanGT
Wow, I definitely got a good laugh out of this thread. 6'2", 230lbs here; I guess I'm NOT one of those ***** featherweight types
Sorry OP, can't help you with the bolt size. Maybe we can get 157db to walk under his car and check :-D
Old May 1, 2010 | 08:42 AM
157dB's Avatar
157dB
Cut & Paste Expert
How cheap are nuts.
Its metric.
Get an assortment and be assured you have
at least one that fits once you squeeze under there
so you dont have to squeeze out and then back in again...
Be sure to take the needed tools into the dark abiss also
or another squeezing trick will be needed...
I'll get some pics up of the OEM set-up.
Or better yet for all of you that dont know that the
workshop manual is ONLINE....
Light and fast.
Its a two to one shot ratio minus the ducking and bobbing....
Dont bring a knife to a gun fight....
carid
Jul 8, 2016 09:55 AM
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
