IAT sensor help
Old May 2, 2010 | 06:50 PM
07vbluestang's Avatar
07vbluestang
Default IAT sensor help
i just bought an IAT relocation senor a couple days ago off a MF forum sposor that i will not mention. it came in a box that was like 7" x 7" and the parts were just thrown in there and lose. on there site it shows the motorcraft box for the sensor and a clear plastic bag with directions and other parts. well it didn't come that way. the sensor was the ford motorcraft part and also had the sensor connector there too with some wire connectors and a wire connector cover. the sensor had no motorcraft box and the threads have this red residue on them. is this a used sensor or do they all come this way? please help before i call and b*tch tomorrow for sending me a used part.
Old May 2, 2010 | 07:00 PM
mustang51js's Avatar
mustang51js
do the wires look cut, seems to me like it might have been installed and returned, the red residue is prob lock tite. But they are easy to install, just take the 2 outside wires going to the maf sensor and splice them in.
Old May 2, 2010 | 07:07 PM
07vbluestang
i have the directions to do the install, i just drilled out my upper whipple manifold today and will tap tomorrow. i just dont want a used IAT sensor and i paid $55 for. Is there something wrong with it, i dont want it to cost me a motor. my concern is the red residue on the threads and it didnt come packaged like it shows on there site.
Old May 2, 2010 | 07:34 PM
2007CalSpec's Avatar
2007CalSpec
The red residue is loctite. I've received sensors and fittings that come with it in the past.
Old May 2, 2010 | 07:42 PM
hammeron's Avatar
hammeron
mine came in a motorcraft box, but i
also purchased it from some on-line
store like rockauto or newfordparts.
sorry if some vendor tried to slip one past you,
it should be discounted if obviously used.
Old May 2, 2010 | 07:47 PM
nem's Avatar
nem
I ordered mine from VMP and it came packaged with the connector and sensor in one box that was NOT a motorcraft. Brand new though and the red is loctite as mentioned above. Hell, Justin didnt even send directions with it.
Old May 2, 2010 | 07:51 PM
hammeron's Avatar
hammeron
mine may have come with some red or orange
goo on the threads too.....
Old May 2, 2010 | 07:56 PM
07vbluestang
ok i will let Brenspeed off the hook!! now do i still put some kind of pipe dope on it before i screw it into the upper whipple manifold?
Old May 2, 2010 | 08:18 PM
hammeron's Avatar
hammeron
i used a little gasket maker on mine, just for good
measure. in this case less is more so go easy on it.
Old May 3, 2010 | 02:31 PM
nem's Avatar
nem
if its your first time installing the sensor you will be ok. if you remove the sensor them use some thread sealant.
