Whining Sound???
Old Aug 3, 2005 | 02:15 AM
biged3's Avatar
biged3
Default Whining Sound???
Ok here is some background info first. About a month ago I was cut off and while swerving to keep the SOB from hitting my right front fender, I put the left rear wheel into a curb, destroying the wheel, and bending a caliper bracket, panhard bar, and left rear axle. Well Ford replaced the wheel, caliper bracket, axle, and axle housing. I got the car back a couple of weeks ago, and it has been running great. I have put close to 1000 miles on it in the past two weeks.
Today I was driving home from Orlando, about 60 miles away, and on the highway the radio station cut out for a second and I not a loud whining sound which sounded like it was coming from the rear end. I was cruising on I-95 at about 80-85 mph. I slowed down to 60... noise still there. I sped back up to 70... noise still there. I got off at my exit, and came to stop at the stop light, noise was gone. I noticed it going away as I slowed down. I know it is not the engine. It is a high pitched sound that seems to start when you hit 20-25 mph. Does anyone have any ideas or guesses what it might be?The car runs fine, but it annoys me now since I know it is there, even though with the windows down you can't hear it, and with the radio on you can't hear it. I just don't want to keep driving it and screw something up. I was going to call Ford to take it in, but I won't be able to get it in until the afternoon, and have to be in Orlando tomorrow morning. I also need the car for a cross state road trip for a wedding this weekend. I was thinking it my just be low on rear diff. fluid. Could this be a cause?
Old Aug 3, 2005 | 02:52 AM
Zeio's Avatar
Zeio
Default RE: Whining Sound???
I have a similar whine sound when I am between 30-60mph upon acceleration and deceleration. I've talked to a lot of people and over a few forums have narrowed it down to gear whine in the rear axle. I almost don't hear it anymore, but I plan on having my gears changed out to 4:10s or 3.73s and imagine that installing new gears will fix the issue. I don't think there is any damage that can happen because of the whine though, but I'm no expert.
Old Aug 3, 2005 | 02:55 AM
biged3's Avatar
biged3
Someone on another forum suggested my wheel bearings maybe causing it. I just noticed it today, and I may be blowing it out of proportion but just wanted some clarity.
Old Aug 3, 2005 | 09:13 AM
hawgman's Avatar
hawgman
I ♥ Acer
ORIGINAL: Zeio
What was the build date of your car and do you have a manual transmission?
Reason I ask is because if your build date was before Jan 15, 2005 you might be describing a problem that there is a TSB out on. TSB 05-8-8
Old Aug 3, 2005 | 10:01 AM
biged3's Avatar
biged3
It was built beginning of May. I do have a manual trans though.
Old Aug 3, 2005 | 10:03 AM
biged3's Avatar
biged3
Hawgman I just looked up the TSBs and saw # 05-7-3, Axle whine for vehicles built through 11/15/04. I am going to call Ford now and see if I can get it in today.
Old Aug 3, 2005 | 11:13 AM
JWB's Avatar
JWB
When I experience a loud whining sound....I simply drop her off at the mall, and it goes away
Old Aug 3, 2005 | 12:02 PM
hawgman's Avatar
hawgman
I ♥ Acer
ORIGINAL: biged3
Well actually I was talking to Zieo on the noise his car was making.
I don't think they (Ford) are going to corolate the 05-7-3 TSB to the noise yours is making because you 6 months out of range on your build date. But ya never know unless you ask.
Old Aug 3, 2005 | 12:34 PM
biged3's Avatar
biged3
ORIGINAL: JWB
Yeah I do the same thing... I wish it was an easy fix this time.
Old Aug 3, 2005 | 12:42 PM
bahbahblacksheep's Avatar
bahbahblacksheep
I think that it is rear axle whine as indicated in the TSB. I don't have this issue, but I would get them to fix it right away
