to make sure my long tubes aren't rubbing it anymore.. i dont care at all bout the engine setting higher... i just want my steering linkage off the tube
+1 on the Prothane mounts, they do raise the motor close to 1/2". I helped install some on my friend's car 2 weeks ago for the same problem you have. It worked.
well yeah i would've dented the header if i had known bout it....butit wasn't worth taking the header back off after its been up and running...are the mounts hard to change?
