Spark Blow Out.
Old May 22, 2010 | 06:07 PM
davisr014's Avatar
davisr014
Default Spark Blow Out.
I think I may be experiencing spark blow out. In first and second I do not notice it, but i go through those gears has fast has I can shift. In third above about 4K it starts to surge/sort of like it is missing. There is no noise or check engine light associated with it. It did it once before the cams and now most every time. When I installed the supercharger I gapped the plugs to .041 per instructions (they said to factory specs). I do have brisk plugs. I plan on changing the gap to .038.
Thanks for your help.
Old May 22, 2010 | 06:42 PM
BruceH's Avatar
BruceH
You may just need new plugs. How long have they been in?
Old May 22, 2010 | 06:51 PM
Stkjock's Avatar
Stkjock
Retired Mod
.041? on a boosted application? that sounds awful big IMHO>
how much boost?
Old May 22, 2010 | 06:56 PM
davisr014's Avatar
davisr014
I have about 2500 on the plugs.
Old May 22, 2010 | 08:05 PM
BruceH's Avatar
BruceH
I'm gapped at .032 with HT0's. Boost is hard on plugs. I change the plugs and fuel filter every November.
AFAIK Brisk longevity is short. I've read more than a few posts from Brisk users who've gotten less use than you have. I think Stkjock is running them, maybe he will chime in on how long he can go on a fresh set.
Old May 22, 2010 | 08:59 PM
Stkjock's Avatar
Stkjock
Retired Mod
I do have them in. First set still in the car. Have about 2000 miles maybe on them.
Old May 22, 2010 | 10:59 PM
bigray327's Avatar
bigray327
You definitely need a smaller gap. I run 0.030". Also... gotta check the obvious... is TCS off?
If it's spark blow-out, you'll be inclined to get fancy COPs. Don't. The stock ones are just fine to huge power levels.
Old May 23, 2010 | 06:14 AM
davisr014's Avatar
davisr014
Thanks for the help I will gab down to 30. The TCS was on.
Old May 23, 2010 | 09:32 AM
Simon1's Avatar
Simon1
YOu don't need to go all the way down to 30. If you are running 10 psi or less you should be at .034-.035.
I have HTO's and have been running them since I got FI. The gap is good to 15psi.
The surging the strange driving you explained earlier sounds more like belt slip or just a plain miss period. I would pull all the plugs, anti sieze them, di-electric grease, torque and drive. IF you still have problems look elsewhere.
Old May 25, 2010 | 10:57 AM
davisr014's Avatar
davisr014
Thanks for the help I went with .031 may try opening up a little. I have only ran it hard once since then, but it ran great. I did also inspect and antisieze the plugs.
