Intake & tuner installed!
Old Jun 7, 2010 | 03:15 PM
baddog671's Avatar
baddog671
Default Intake & tuner installed!
Just put my C&L Racer on aswell as the Brenspeed 87 tune, can't wait to put the pedal to the metal here shortly.
I didn't install the heat shield with the intake. As stupid as it sounds, I could not get it to line up with anything. The single bolt hole was about 1" from lining up, the other side hit all the ABS lines, and the only way I could make anything line up is if I cocked it at like a 30-35degree angle, which I don't really understand.
Either way, I think it looks cheap anyways, especially compared to the FRPP intake's shield. I expect it won't really matter with the underhood temps, correct? I don't do much city driving, and next mod is coated Kook's LT.
Old Jun 7, 2010 | 03:18 PM
2cokeman's Avatar
2cokeman
PICS PICS........Should have the heat shield to protect from the heat of the manifold??
Old Jun 7, 2010 | 03:21 PM
baddog671's Avatar
baddog671
I'll go snap a picture. Car looks stock because so far all I have is the intake/tune, BMR rear LCA's, SM aluminum DS, and Saleen pullies sitting around ready for install.
Edit: The rear and rear side windows are tinted aswell. Going to do 15% all around and 50% windshield later on in the year.
Old Jun 7, 2010 | 03:57 PM
Money$hot's Avatar
Money$hot
tinting the windshield? Must be a lot of city driving
Old Jun 7, 2010 | 04:00 PM
baddog671's Avatar
baddog671
Old Jun 7, 2010 | 04:18 PM
AU2BOT's Avatar
AU2BOT
Your in for some excitement, have fun and be safe!!!
Old Jun 7, 2010 | 04:28 PM
Unleashedbeast's Avatar
Unleashedbeast
See, this tricked me at first as well. Stretch the shield to the opposite side of the ABS block lines like the picture below. It will fit just fine.
The first time I installed it I mistakenly placed it in front of the ABS block lines, and it didn't fit well.
Old Jun 7, 2010 | 04:34 PM
Unleashedbeast
I have 35% on the entire windshield with a 5% eyebrow top strip. No one can see me in the car, and I like it that way.
Old Jun 7, 2010 | 04:37 PM
AU2BOT's Avatar
AU2BOT
Looks great , you should check out SliverHorse Racing for the lower grille inserts they fill up that hole in your lower grille and makes it look a whole lot better, just a suggestion
Old Jun 7, 2010 | 04:44 PM
usmcmp90's Avatar
usmcmp90
hey man, give us an update once u start driving it around. i'm getting the same intake and tune from Brenspeed so it'd be kool to get some reviews
