Passing Inspection with SCT
Hello all,
I haven't posted in a while so hello to all.
I have an SCT tuner and cold air intake made by Tunable Induction. I am using their pre-set tune on my 2005 v6 mustang.
I have never had a problem passing inspection before, but now I am getting the message 'unsupported' for all the OBD sensor readings. Is this because of the tuner? I have never had this problem before getting the car passed even with the SCT.
I am not sure where my SCT tuner is because I figured I'd never have a problem, but I guess I was wrong. Could I try taking off the negative battery terminal for 20 minutes or so and then driving it and trying again or will only resetting the computer to factory settings fix this problem?
Thanks for any help,
Mike
Mike
Hello all,
Mike
Mike
You don't need to unhook the battery. Just load your stock tune back in (you may need to put your stock airbox on too) and drive around for about 50 miles. I have learned the hard way that it is the only surefire way to pass NY inspection.
