UDPs
Old Aug 31, 2010 | 08:25 AM
highline's Avatar
highline
Default UDPs
BBK, Saleen, Steeda...Are there differences? Which do you recomend? Also, I've heard there may be differences between the 05-07 and 07-09 GTs? Any help would be appreciated, and I guess most importantly are they worth it...I'm not looking for 234 rwhp, but a little less ac drag here in h*ell (Houston) would be cool...Thanks in advance...
Old Aug 31, 2010 | 08:39 AM
ronniegibson1978's Avatar
ronniegibson1978
to me personally, you're not gonna notice any differences between the different companies
Old Aug 31, 2010 | 08:55 AM
highline's Avatar
highline
Thanks for the info...I'm WAY more stock than you, and was wondering if it was a worth while mod that I could do...
Old Aug 31, 2010 | 09:46 AM
acascianelli's Avatar
acascianelli
I have the Steeda UDP on mine. Didn't really notice much of a difference to be honest. I'm sure there is a difference, but it's not very noticeable. Even with that being said, I would recommend them because they are relatively cheap. Keep your stock balancer if you ever plan on supercharging.
Old Aug 31, 2010 | 10:07 AM
ronniegibson1978
you won't notice any power difference at all...the one thing i did notice is my mpg's went up like 3
Old Aug 31, 2010 | 11:41 AM
Nuke's Avatar
Nuke
UDP's will supposedly free-up about 3-5 RWHP. The average driver won't notice that with the Butt Dyno.
I highly doubt that UDP's will make ANY difference in your mileage. Since I've driven the exact same 420 mile run, stopping at the same gas stations, driving with cruise control at the same speeds almost every 2 weeks for almost 2 years I can tell you that you can do NOTHING to the car and still see swings of 4 MPG or more difference from trip to trip. There are so many variables I'd be out of breath. The 4 MPG that ronniegibson1978 is referring to is NOT UDP related.
Old Aug 31, 2010 | 11:53 AM
UltraKla$$ic's Avatar
UltraKla$$ic
Whether they help or not, give better gas mileage, or feed you breakfast in the morning, I love mine! They look hella sharp!
Saleen FTW!!!!
I do notice a bit of quicker revs, but I do have a good tune too.
Old Aug 31, 2010 | 12:07 PM
ronniegibson1978
i'll give ya that ultra..they do look d@mn good
Old Aug 31, 2010 | 12:08 PM
UltraKla$$ic
Exclamation
A tidbit of info though for those choosing the Saleen UDP's, that being, familiarize yourself with your OEM alternator and how it's pulley is actually on the alternator itself. There are 2 ways these pulleys can be attached to the alternator because of 2 running versions of alternators. One version has a bolt that you spin off and the pulley comes off, and the second version has a SPLINED pulley WITHOUT a bolt(like mine). The Saleen UDP is useless in the second application, because the Saleen UDP is NOT splined.
CLear as mud? Good.
Old Aug 31, 2010 | 12:09 PM
baddog671's Avatar
baddog671
Saleen FTW!!!!
Hey, those look familiar
