A Frustrating Problem
Old Sep 5, 2010 | 09:50 PM
JMBE's Avatar
JMBE
Default A Frustrating Problem
I have a 2005 V6 that has a frustrating intermitent problem. Every so often I the car starts to hesitate, stall, buck, basically run roughly. I have even had it lock out the acceleration pedal until I cleared the codes. The problem goes away after I remove the air cleaner and idol the engine with the air cleaner removed. Then everything starts to run normal again.
The codes that come up are P2135, P2104, P2106, P2111 and P2112. I am thinking it is the Mass Air Flow Sensor and when it fails triggers these problems. Any ideas?
Old Sep 5, 2010 | 09:59 PM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Have you cleaned the MAF with MAF cleaner?
Also is the filter clean?
Id make sure both were clean and even think about cleaning the
throttle body.
Old Sep 6, 2010 | 08:03 AM
2005Redfire6's Avatar
2005Redfire6
throttle body.
+1, my 5-speed will buck like a bronco coming out of first sometimes and its usually when a bunch of people are looking in a parking lot... :|
Old Sep 6, 2010 | 08:52 AM
MOOK3456's Avatar
MOOK3456
If you have the codes, why are you guessing?
P2135- Throttle/Pedal Position Sensor/Switch "A" / "B" Voltage Correlation
P2104- Throttle Actuator Control System - Forced Idle
P2106- Throttle Actuator Control System - Forced Limited Power
P2111- Throttle Actuator Control System - Stuck Open
P2112- Throttle Actuator Control System - Stuck Closed
Old Sep 6, 2010 | 09:05 AM
Nuke's Avatar
Nuke
Certainly begin by cleaning the TB and MAF and installing a new filter. Quite often, unrelated codes can be thrown due to air flow restrictions, air leaks, dirty equipment.
Old Sep 6, 2010 | 12:32 PM
808muscle's Avatar
808muscle
Yup!
Old Sep 6, 2010 | 01:35 PM
HypromanGT's Avatar
HypromanGT
Yeah isn't it great? This car, as much as I do love it, does enjoy making me look like a fool, and this is one way it can do it. One of these days I'm going to datalog this issue and see what's going on. In general this car can get very angry when pulling away from startup, even if you let it run for a minute. I don't get it...
Old Sep 6, 2010 | 02:15 PM
baddog671's Avatar
baddog671
I thought this problem was just mine, but yeah, my car is grumpy when the engine is still cold. Bucks, kicks, and seems torque-y as hell
Old Sep 6, 2010 | 04:56 PM
pascal's Avatar
pascal
S197 Section Modder-ator
I agree with all of the above.
Basically, maintenance is required...
Just for good advice: DO NOT, run your engine without an air filter, even for a short while.
You will get a funky code for sure (YEIF 101) lol.
JoshyGT
Sep 19, 2017 08:52 PM
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
03blackwidow
Sep 20, 2015 02:36 PM
