higher octane then 93?
Old Sep 12, 2010 | 05:22 PM
Roush06GA's Avatar
Roush06GA
Default higher octane then 93?
how many gallons do you put into your car.. how often. what are the positive and negative of higher octane? just wanted to know yall's thoughts.
"i know it cost more"
Old Sep 12, 2010 | 05:57 PM
siggyfreud's Avatar
siggyfreud
Will do nothing for you unless your computer is tuned to take advantage of it. Higher octane takes longer to burn. In theory, you'll get the best performance from the LOWEST octane your engine can run maximum tuned (meaning what its already tuned for) timing at and not detonate.
Old Sep 12, 2010 | 06:03 PM
lizzyfan's Avatar
lizzyfan
Underboss
waste of money if not tuned for
Old Sep 12, 2010 | 06:07 PM
howarmat's Avatar
howarmat
s197 Junkie
like stated its not doing much for you unless you have a tune for it. 94 running on a 93 might work if the 93 tune had a little ping or if you increase the settings manual with the tuner and the 93 tune.
Old Sep 12, 2010 | 06:40 PM
Nuke's Avatar
Nuke
Enough to fill it.
As stated above, you need to be tuned for higher octane to take full advantage of any power gain.
Old Sep 12, 2010 | 07:59 PM
tigercrazy718's Avatar
tigercrazy718
where do they sell 94 octane?
Old Sep 12, 2010 | 08:03 PM
2cokeman's Avatar
2cokeman
Sunoco in Canada has 94
Old Sep 12, 2010 | 08:05 PM
howarmat's Avatar
howarmat
s197 Junkie
a couple stations do, Phillips 66 and Sunoco are the ones i know do in my region
Old Sep 12, 2010 | 09:19 PM
tigercrazy718
hmm cant find that in louisiana or texas
Old Sep 12, 2010 | 11:57 PM
Roush06GA's Avatar
Roush06GA
im in ga so i go to this local gas station that sells 98 and 110.
