Auto window close after door is shut--2005 Mustang GT
Old Sep 15, 2010 | 03:06 PM
tonylentini's Avatar
tonylentini
Exclamation Auto window close after door is shut--2005 Mustang GT
When I bought my Mustang and saw the window that rolls down slightly when you open the door and then closes fully when the door is shut, I thought "there's something that can break," and mine has:
The window on the driver's door rolls down slightly when the door is opened but doesn't roll back up when the door is closed. Is this something I can fix myself, some sort of sensor or something? If not, what is it likely to cost at the dealer.
Also, after 5 years am having a problem with the gauges: Tac is like the needle is loose on its pin (it doesn't register at right at all) and now, my oil gauge is off center (the needle range is shifted left and up past the Low Pressure indicator). How hard is this to fix?
Noting some slippage in tranny in Drive now on occasion. I have maintained the car well but now am worried things are starting to fail. Advice, please????
Old Sep 15, 2010 | 03:30 PM
tonylentini
Smile Window Timing Problem
Fixed my window issue after talking to a Ford Service Technician:
Windows open and close slightly when doors are opened and closed. My driver's side door quit going back up. It's called a Window Timing Problem and easy to fix:
1. Turn ignition key to where gauges light up but car doesn't start.
2. Push both windows (driver and passenger) down and hold for six seconds.
3. Pull both window switches up to close and hold up for six seconds.
4. Repeat step two.
5. Repeat step three.
6. Turn off ignition.
7. Start car.
8. Turn off car and the windows should operate properly again.
Old Sep 15, 2010 | 03:46 PM
kevinmalec's Avatar
kevinmalec
Good to hear you were able to resolve the window issue!
Thanks for sharing how fix it. ;-)
Old Sep 15, 2010 | 03:54 PM
kevinmalec's Avatar
kevinmalec
BTW, someone in the V6 sections just posted the same window issue!
I just copied and pasted your instructions and sent it to him.
How ironic??!!
Gotta love these forums!
Old Sep 15, 2010 | 04:18 PM
Nuke's Avatar
Nuke
That window recalibration procedure is in the Owners Manual, BTW.
Old Sep 15, 2010 | 08:41 PM
2005Redfire6's Avatar
2005Redfire6
4. Repeat step two.
7. Start car.
Good ole' window reset, thats what I was going to suggest.
Old Sep 15, 2010 | 09:41 PM
Biceps's Avatar
Biceps
How ironic??!!
Weird, I just started having this issue too, and I own a 2008 v6.
Old Sep 15, 2010 | 09:55 PM
marcuskeeler's Avatar
marcuskeeler
Plus it's firmly in the top 5 of any Mustang FAQ listing hehehehehe
Old Sep 15, 2010 | 10:28 PM
stang06lv's Avatar
stang06lv
Ya but has anyone had the problem where the window goes up to far? and you realize it when you shut the door..Well i have...the glass was literally outside of the car, cant remember how i fixed it tho..
Old Sep 16, 2010 | 08:41 AM
incorrigible's Avatar
incorrigible
There's a reset procedure for that as well in the owners manual.
