Strut question
Old Oct 28, 2010 | 08:36 AM
67stangr's Avatar
67stangr
Default Strut question
Are the struts on a 05-09 v6 the same as a gt? I need new ones.
Old Oct 28, 2010 | 10:29 AM
Roy_R's Avatar
Roy_R
I don't know, but if they are, see my sig
Old Oct 28, 2010 | 11:12 AM
157dB's Avatar
157dB
Cut & Paste Expert
Um, no.
Different rebound rates.
Get Koni and never look back.
But if you dont mind so-so performance,
get the GT struts and put them on
your V6.
You probably wont know the difference.
Install the GT springs and GT front sway
bar while you are at it. Heck why stop
there. Put a 4.6L three valve in there as
well and them the suspension will handle
like OEM.
Dont forget to upgrade to the GT500 upper
strut mounts while you have the struts off
for replacement.
2007 year model and he 'thinks' he needs new struts. ??
Did you run your S197 in the Baja 5000 this summer?
I thrash my 2007 S197 daily and the struts show no
signs of wear yet. Or the brakes for that matter...
Old Oct 28, 2010 | 12:36 PM
Nuke's Avatar
Nuke
Interesting question from 157db...
Why do you need new struts? Unless one or more have failed catastrophically, you shouldn't "need" new ones unless you've capped at least 100,000 miles. I don't get surprised with struts lasting up to 200,000 miles. Wait, you didn't go to Midas or a Quik-Lube for that info, did you?
Old Oct 28, 2010 | 02:44 PM
67stangr's Avatar
67stangr
I did not go to any quik lube or midas, im not a retard. There is a noise like theres something loose in the front end like the damn struts!
Old Oct 28, 2010 | 03:30 PM
Nuke's Avatar
Nuke
Relax. I'm not implying anything here.
Now that you've mentioned a noise in the front end, are you familiar with the front end clunk TSB? You may be replacing the struts when it's not needed.
Old Oct 29, 2010 | 11:04 AM
157dB's Avatar
157dB
Cut & Paste Expert
A retard in the aspect that you cant use the search function.
Search 'chuckle' or 'front end clunk'.
Then check your sway bar end links for proper tightness.
Then buy the GT500 upper strut mounts and be happy
you didnt have to lay down cash for new struts when
the old ones are perfectly fine.
Struts dont clunk unless they are really trashed and
the upper seal/bushing is gone and all the fluid has leaked
out.
Any of these things apply to your struts?
Settle down there cowboy, we are all here to help,
not call each other morons.
Next question....
My gas tank is empty, anyone know where to purchase
a filled gas tank?
Old Oct 29, 2010 | 11:46 AM
Nuke's Avatar
Nuke
Originally Posted by 157dB
...Settle down there cowboy, we are all here to help,
Next question....
a filled gas tank?
Old Oct 29, 2010 | 08:00 PM
67stangr's Avatar
67stangr
I have used the search function many times and never really found what i was looking to get, so what should i do short of replacing the struts?
Old Oct 29, 2010 | 08:15 PM
JDWalton's Avatar
JDWalton
All the info you need:
http://tinyurl.com/2eh5c2h
