Failed Emissions - Help Please !
Old Nov 17, 2010 | 03:41 PM
wasvette's Avatar
wasvette
Default Failed Emissions - Help Please !
Took the car today for emissions (all obd2 port, no sniff in exhaust) and it failed the 1st time for "READINESS". This was with a VMP 93 tune for cold air, gears, and cmdp. I wasn't surprised so...
I went home and installed the Bama 93 race tune that was on it last year for the same mods - it PASSED last Novemeber. Well it failed again today for "READINESS". I talked to a well known local shop here and they thought since I just flashed it that it hasn't gone through enough ignition cycles...drive, cool down, drive, cool down, etc. hence readiness issue.
Is this the case? Does anyone know how many ignition cycles I'll have to go through and if this will eventually pass the "READINESS" issue?
Old Nov 17, 2010 | 03:50 PM
ffk_pennywise's Avatar
ffk_pennywise
When mine failed, I loaded up the emissions tune from Brenspeed the next morning before work. Drove to work then afterwards I drove back to the shop and passed. 80 miles total. I think its a mileage thing, not on/off cycles. My car was only turned on/off probably 3 times.
Old Nov 17, 2010 | 04:00 PM
wasvette's Avatar
wasvette
thanks ffk - I'm going to drive the heck out of it tomorrow - I've got to get this passed by friday afternoon. I am confident the tune will pass if I can get past the readiness thing.
Old Nov 17, 2010 | 04:04 PM
Derf00's Avatar
Derf00
Gentleman's Relish
It's not the number of miles you drive or just the number of times you start the car. It's whether or not certain driving conditionsare met that allows all of the sensors to go through their required checks.
If you drive about 15 minutes around town. Turn the car off and let it cool down for a few hours then drive it on the freeway for about 15 minutes you should be fine. Some sensors do require additional igntion cycles to be "ready".
THere's info in most repair manuals about how to complete a "Sensor Readiness Drive Cycle" or somethign along those lines. The Owners manual may even have it. It's a lot of steps but if you think about it, under normal driving conditions you do most if not all of them.
P.S. if your tune shuts off the rear O2 sensors you may never be "ready" because the OBDII never receives confirmation from the sensor its gone through its check.
Old Nov 17, 2010 | 04:22 PM
wasvette's Avatar
wasvette
derf00 - Thank you. All makes sense. I'm not sure if this tune turns off rear o2s and I can't keep going back. So I might just order an emission tune and drive around for 2 days.
Old Nov 17, 2010 | 04:49 PM
Roy_R's Avatar
Roy_R
http://www.cleanairforce.com/docs/readiness.pdf
Old Nov 17, 2010 | 05:21 PM
wasvette's Avatar
wasvette
Originally Posted by RideMyAssOff
Sweet - will go through this tomorrow - thanks
Old Nov 17, 2010 | 06:07 PM
2005Redfire6's Avatar
2005Redfire6
I believe its a matter of mileage after reflash aswell.
Old Nov 17, 2010 | 07:45 PM
SpartaPerformance's Avatar
SpartaPerformance
Drive about 30 miles in three speed ranges form 0-20, 20-40, and 40+
Old Nov 18, 2010 | 06:54 AM
wasvette's Avatar
wasvette
Thanks everyone - will try today
