seat belt
Old Dec 17, 2010 | 03:55 PM
Recon111's Avatar
Recon111
Default seat belt
Every mustang I have owned, the female end of the seat belt is about 1 inch to short. If it was just a little longer it would be so much easier to connect .
Old Dec 17, 2010 | 04:28 PM
stang06lv's Avatar
stang06lv
do what i do and not wear one.
Old Dec 17, 2010 | 04:46 PM
siggyfreud's Avatar
siggyfreud
Darwin at work.
Old Dec 17, 2010 | 04:49 PM
alkemist's Avatar
alkemist
You probably have insurmountable issues with airplane seat belts then.
Old Dec 17, 2010 | 06:00 PM
Recon111's Avatar
Recon111
I quit flying after the terrorist BS and I always were a seatbelt.
How do you post pictures?
Old Dec 17, 2010 | 07:03 PM
wayne613's Avatar
wayne613
¨Insert Image¨ button in the mini-toolbar above where you type your response. Needs to be a web-linked image. Plenty of free picture dumping grounds to house ´em if it´s one of your own, image dump, imageshack.us, etc..
Old Dec 17, 2010 | 08:23 PM
siggy14's Avatar
siggy14
You could always get these
http://www.casualmale.com/store/en_U...&id=cat3360203
Old Dec 17, 2010 | 08:37 PM
JimC's Avatar
Super Moderator
Stop by the dealership parts department. They should give you some extender attachments at no cost. I have them for my convertible because the way the shoulder mount is set up it hits my neck.
Old Dec 17, 2010 | 09:06 PM
Recon111's Avatar
Recon111
JC thanks
Wayne
I guess it's time thing. I have nothing like what you describe.
Old Dec 17, 2010 | 09:26 PM
wayne613's Avatar
wayne613
Wayne
Editing your posts are I think. Have to be like over 40-45 posts to have it enabled.
However, the WYSIWYG editor is not. Under your ¨User CP¨, click ¨edit options¨, then at the bottom where it says Miscellaneous Options, select advanced editor - WYSIWYG Editing.
Become one with the WYSIWYG Daniel-san. Or you can just add the brackets for it manually
Code:
[img] http-image-reference-here [/img]
I´m just so used to the altered html formatting these message boards use I rarely ever use the buttons for doing it for ya.
