P2104 and P2111 error codes
Old Jan 7, 2011 | 11:05 PM
A967A's Avatar
A967A
Default P2104 and P2111 error codes
Can anyone help me???? I have these codes and my car will only idle. Its like the gas padel does not work. The car will only idle and will not go over 5 mphs... PLEASE HELP!!!!
Old Jan 7, 2011 | 11:19 PM
wayne613's Avatar
wayne613
Pretty much right here.
This might do it, then again it might be another sensor that´s related, but worth a go.
Old Jan 7, 2011 | 11:28 PM
A967A's Avatar
A967A
Thanks man, but I am trying to find out how to fix this prob
Old Jan 7, 2011 | 11:31 PM
A967A's Avatar
A967A
Like do I have to have the computer flashed or do I have to replace the T.B., Sensors, plugs etc....?
Old Jan 7, 2011 | 11:38 PM
wayne613's Avatar
wayne613
Edited previous reply, refresh for the other link I provided. Walks you through cleaning it out on a ¨lightning¨, same basic idea. I know jack and squat about the mechanical aspects, but googling the issues...I have a masters.
As I said, no expert surely, but other than cleaning it, I can´t see why you´d need to replace the actual TB, just the few related sensors once you figure out which one exactly. My guess would be you could use the MAF cleaner on the TB sensor itself to try and see if just that sensor itself is the issue. Meh, thread states it´s self-contained, so can´t clean the sensor itself. Ghey.
Here´s a better thread that´s related.
Specifically this part:
As said before becareful cleaning it. also ford has a updated tps sensor which I replaced because my GT keep going into limp mode,bad corralation between sensor a&b (throttle circut) hope this helps.
Just keep checkin´ back later, I´m sure one of the guys that can actually give real insight beyond this will see this eventually and likely chime in, just won´t be super-quick.
Old Jan 8, 2011 | 12:03 AM
A967A's Avatar
A967A
Thanks again man, its my only car, so im kinda freaking out because it is my transportation! and its all stock to! It should not have this prob!
Old Jan 8, 2011 | 12:10 AM
wayne613's Avatar
wayne613
Np man, and in the mean time if it were my car I´d be burning google up with ¨mustang¨, ¨tps sensor¨, those codes, and the like in searches as mine is my only vehicle at the present as well. Any way you slice it your likely going to need to replace something, but you might find a temp solution this way, and avoid a dealership service ´cha-ching´.
Not to mention not having to drive on the shoulder with the hazzards on, having amish kids with a horse drawn buggy pass you and laugh in the meantime .
Old Jan 8, 2011 | 11:13 AM
mcgyvertech's Avatar
mcgyvertech
That same thing happened to me three days ago. Taking off from a light and the engine nearly died. I barely made it off of the road. Pulled the same codes, cleared them and had it towed home. That night I couldn't make it run but the next morning it started and ran fine. I ordered a new throttle body w/ TPS and throttle motor, but cleaned the old one and so far so good.
Old Jan 8, 2011 | 02:14 PM
A967A's Avatar
A967A
Well just got done at the dealership. Yes i know, they robbed me. Short Story I'l expand on later...... There is a spring/coil thingy that is on the T.B. that controls the flaps inside it. The spring/coil had jumped outta wack and that was what caused this problem!!!!! A little B.S. problem that cost $136 to fix... So hope this helps. Message here if u need more detailed informaton!!!!
Old Jan 8, 2011 | 04:17 PM
wayne613's Avatar
wayne613
Actually, someone correct me here if this is wrong, but $136 isn´t bad. Unless it´s a pretty straight forward code(s) and symptom thrown you could have spent far more than that trying to replace just parts, not counting extra time/effort. Kind of a good deal from a dealership shop fix, I may faint.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
ChampInSD
Oct 2, 2015 04:55 AM
