check fuel cap
Old Jan 24, 2011 | 07:10 PM
nola504boy's Avatar
nola504boy
Default check fuel cap
do anyone know what this means? thats what my dash is reading. my fuel cap is on tight but it keeps saying this and its been 2 weeks now and I have bought gas twice since. please help im going crazy.
Old Jan 24, 2011 | 07:20 PM
Torch Red GT's Avatar
Torch Red GT
did you try resetting the code?
Old Jan 24, 2011 | 07:26 PM
nola504boy's Avatar
nola504boy
no i didnt should i hook up my handheld tuner and do this or can it be done at the dash itself?
Old Jan 24, 2011 | 07:33 PM
Torch Red GT
try hooking up your handheld and see the code it throws, and then reset the code. The problem should be solved after that
Old Jan 24, 2011 | 07:56 PM
AzPete's Avatar
AzPete
It is normally a reference that the cap is loose or the tank venting system is not functioning properly. If it was just a cap issue, it should automatically reset as my '07 GT Vert would. Might check the cap for damage.
Old Jan 24, 2011 | 08:00 PM
nola504boy's Avatar
nola504boy
Thanks guys I will check it tomorrow. Btw I almost ran out of gas a few weeks ago don't know if this is the reason for the problem.
Old Jan 25, 2011 | 01:34 PM
07 Stang's Avatar
07 Stang
I had that problem with my E-350. Took it in to the dealer and they said it was a faulty sensor. Haven't had a problem sense.
Old Jan 25, 2011 | 06:05 PM
jlc41's Avatar
jlc41
I had a similar problem and it was the gasket seal at the cap, it had dride out and was cracked.. Replaced the cap and the code reset after two tank fills. Hope that helps.
Old Jan 25, 2011 | 09:07 PM
nola504boy's Avatar
nola504boy
Thanks for all the input guys. Still haven't had a chance to check nit yet.
Old Jan 26, 2011 | 07:11 AM
incorrigible's Avatar
incorrigible
It may take a couple of driving cycles to clear. Give it some time.
