front sway bar needed?
Old Feb 2, 2011 | 01:31 AM
08blackoutstang's Avatar
08blackoutstang
Default front sway bar needed?
Ok so before i re do my stripes install my scoops or anything i want to figure out this knock! I already have had my front a arms and ball joints replaced and it took car or 70% of the knocking, now i am moving on the the sway bar before i attack the upper strut mounts. What exactly is the need for a front sway bar on a lowered vehicle? Can i ditch it completely?
Old Feb 2, 2011 | 08:33 PM
charliebrown266's Avatar
charliebrown266
The clunking may be the sway bar links or the upper mounts
Old Feb 2, 2011 | 09:16 PM
08blackoutstang
but do i need a front sway bar
Old Feb 2, 2011 | 09:27 PM
smokinAMD's Avatar
smokinAMD
Do you like to drive your car in corners at a reasonable rate of speed? Do you dislike body roll? If you answered yes to either of these questions, yes, you need a swaybar.
Do you only drive your car on the 1/4 mile? Do you drive like a grandpa all the other time you aren't on the 1/4 mile? If you answered yes to either of these questions, no, you don't need a swaybar.
Old Feb 2, 2011 | 10:57 PM
2005Redfire6's Avatar
2005Redfire6
Reason why I sold the GT Takeoffs and going to remove it for the track...
Old Feb 3, 2011 | 01:38 AM
08blackoutstang
maybe ill look into an after market one
Old Feb 3, 2011 | 08:25 AM
Cal26Stang's Avatar
Cal26Stang
It's always a benefit to beef up your frame strength
Old Feb 3, 2011 | 04:25 PM
tx_zstang's Avatar
tx_zstang
I remove my front sway bar for drag racing and leave it off most of the time.
But as mentioned, if I plan on doing any twisty-windy driving, I'll put it back on.
Do you NEED it? no, but it helps street handling.
Old Feb 3, 2011 | 05:56 PM
baddog671's Avatar
baddog671
I took the front swaybar off my old 98v6 once and drove it for a few miles. Cornered like a boat
Old Feb 3, 2011 | 06:01 PM
Alec's Avatar
Alec
Needed? No, but your car will handle like schit on the street. My GT front sway is noisy over speed bumps but it's something I can live with
