engine gurus i need help, again
Please bear with me this is a tricky issue so there's some explaining.
Back date to October, car throws a code for cyl8 coil pack intermittent. symptoms check out, replace packs with MSD packs, car runs fine. (I dont drive her too often so...) 2 weeks later i take her out and she starts acting up again as if the coil pack had gone, throws a code for cyl 5 coil pack, well theres less than 10 miles on these coils so, i swap cyl #2 coil w #5 coil to see if it follow the coil, no such luck, stays with cyl #5. clear the codes run it around the block, new code(s), both front 02 sensor heater circuits. replace the 02's (they needed to be anyway) same codes.
Now its mid November, and I already have a stock pile of parts for my winter build, so I figure Ill start my build and check over everything, see if anythings FUBAR-ed.
Heres a list of installed / replaced parts:
Comp cams bee hive valve springs
titanium valve retainers
FRPP hot rod cams
FRPP 24# injectors
BBk Fuel rails
FRPP intake manifold
FRPP twin 62mm TB
JLT air intake
02 sensors (front only, rears are delete)
MAF sensor
Fuel filter
Finished the build Mid january, starts up, wont idle, runs rough, throws a code for cam angle sensor bank 2. check the sensor, looks good, asked a tech who said with all my previous issues i might want to look at the alternator, which has been known to cause similar issues. so I ordered up a new alternator
Fast forward to yesterday, got around to putting the alternator in, go to start the car, turns over but its not catching, feels like timing is off. set spark timing to -2, fires up, throws the same code, bank 2 sensor, so ok maybe the sensor is shot, but bank 1 and 2 have the same sensor so lets swap and test, same output as bank 2, therefore its not the sensor. today i pulled the valve cover off bank 2 to check if there was blockage or anything not right, and everything appears to be spot on. I dont have a scope to test the ranges of the sensor but i was able to do a continuity test on the wiring, and there is continuity, so i doubt its my harness. I also checked the pins on the PCM to make sure they weren't loose or bent.
Im basically at a road block where, seeing that everything appears mechanically sound, the sensors appear to be functioning, and the harness appears to have no shorts, I'm nearly at a loss. Could my PCM be defective? Is there anything else I should look into?
any help is much appreciated.
Car:
05' GT 5spd M
FRPP hot rod cams
FRPP 24# injectors
BBk Fuel rails
FRPP twin 62mm TB
JLT air intake
MAF sensor
Fuel filter
Car:
05' GT 5spd M
If you are talking about TSB 08-26-07 then generally no. That puts the SJB in danger and normally only messes with the lights and electronics of the car, however 05sonic3valve have you had that taken care of? Also all these CELs that are popping up, do the symptoms of the suggested problem show up as well every time? sound random. who wrote your tune? good luck man sounds you know what you are doing and have exhausted every option.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
TfcCDR
Sep 14, 2015 12:08 PM
