Front end conversion
Old Feb 19, 2011 | 05:09 PM
bodydrop21's Avatar
bodydrop21
Default Front end conversion
wondering if i can take a 2011 gt front end and put it on a 2006 gt? Does anyone know if it will work?
Old Feb 19, 2011 | 05:11 PM
jpormen's Avatar
jpormen
If you can find the parts im sure it could be done, might easier and less of a hassle to buy a nice aftermarke bumper or body kit
Old Feb 19, 2011 | 05:50 PM
SCCAGT's Avatar
SCCAGT
Sure it can be done. You'll need the fenders, headlights and hood too. Otherwise they wont line up correctly. Then you will need new door skins, and rear quarters to match the front fenders, since the body lines are slightly different. Then a rear bumper cover, and trunk lid will be necessary to line up with the rear quarters.
Other than that, your good to go.
Old Feb 19, 2011 | 07:20 PM
grabber blue gt's Avatar
grabber blue gt
Crash your car and have them swap it with 2011 parts, that way insurance pays for it.
Old Feb 19, 2011 | 07:29 PM
ReaperGT's Avatar
ReaperGT
You could probably just do it by buying the fenders, hood, bumper, grille and headlights and then flowing the body lines into your current door but that depends on the skill of your bodyshop
Old Feb 19, 2011 | 08:11 PM
JIM5.0's Avatar
JIM5.0
Is this for real? I thought once you get to the fenders, they were 100% compatible with all S197 bodies.
Old Feb 19, 2011 | 09:00 PM
stealth_GT's Avatar
stealth_GT
Get a GT500 front end and be done with it
Old Feb 20, 2011 | 09:19 AM
CutterWolf's Avatar
CutterWolf
Can it be done? Sure, but you would need to do a TON of body work on top of all the parts need. Check out the body lines of the 2010-11 and then look at the body lines on the 2005-9. They don't match up at all plus look and the fender well body lines, again they are no where close to the same.
Old Feb 20, 2011 | 09:30 AM
JIM5.0's Avatar
JIM5.0
How far off are the fender lines from the 10-11 plastic front end and rear fascias? Would it be noticeable from normal eye view? Or do you have to be really close in to see the mismatch?
Old Feb 20, 2011 | 03:37 PM
Tanner05's Avatar
Tanner05
Chop Mod
It would be really cool if you could get this to work. Its will end up being really expensive though.
